5.8L Distributor
Old Dec 4, 2002 | 01:11 PM
apriliarider's Avatar
apriliarider
5.8L Distributor
I'm swapping out my 5.0 for a 5.8 and was wondering if the distributors are interchangeable or not. The one on my 5.0 has a different connector then the donor 5.8 that I bought. I know the firing order is different, no big deal I can switch the plug wires around. Also what about timing the manual I have is kind of confusing. Finding top dead center for the number one cylinder isn't tough, but what about installing the distributor. Is it simple and the book is making out to be a complex job. I'm swapping a 5.0 out of a 1992 F-150 to a 5.8 out of a 1991 Bronco.
Old Dec 4, 2002 | 02:49 PM
Redneckerson's Avatar
Redneckerson
5.8L Distributor
The 351w has a taller deck height than the 5.0 so the distributors will not interchange (plus the 5.8 has a larger diameter shaft). After you find tdc, point the rotor button to # 1 on the distributor cap and install the distributor. It will vary a little bit either way as you must mesh the teeth on the distributor to the cam gear. If your close to tdc the engine will "start" then you can set your initial timing with a light after you start the engine. Don't forget to disconncet the spout connector when setting initial timing. Good luck.
RSH
Old Dec 4, 2002 | 05:38 PM
firestorm's Avatar
firestorm
5.8L Distributor
90' XLT
Oct 21, 2021 01:34 AM
fordboy97
Oct 21, 2015 08:42 PM
newr
1978 - 1996 Big Bronco
Jan 31, 2015 10:40 PM
CSJohnson
Feb 12, 2014 09:31 PM
Some Car Guy
Mar 13, 2002 12:36 AM
