ignition switch problem
Old Dec 2, 2002 | 08:16 PM
lr's Avatar
lr
i have a 1989 f250 4x4. the problem started when i got in the truck this morning to move it, and in the process of starting it something in the ignition switch broke and is now stuck in the "run" position. i know i have to get a steering wheel puller to even think about fixing this problem. my question is how hard could it be to fix myself or is this something that i should take to someone else?
thanks
lr
Old Dec 2, 2002 | 08:49 PM
craterjoe's Avatar
craterjoe
Check out the other thread running currently in this area with the same subject. I think you may have the same problem and this may give the answers you seek.
Let us know how it turns out
craterjoe
Old Dec 2, 2002 | 10:50 PM
steve83's Avatar
steve83
I never use a wheel puller. I just back the nut off so it barely clears the end of the shaft (you want as many threads still meshed as possible), put my knees behind it pulling hard, and smack the nut SQUARE with a heavy ball-peen hammer until it lets go. Then pull the nut & the wheel. :-) I've done it several times on several vehicles with no problems.
Old Dec 2, 2002 | 11:01 PM
brett_d's Avatar
brett_d
The part that is broke is called the "ignition Actuator". It is roughly $10.00 at your local ford dealership. Is your steering tilt or normal?
Old Dec 3, 2002 | 06:52 AM
lr's Avatar
lr
my steering is tilt. and after i think about it i believe i'm just going to have someone fix it. it's hard for me to get time during the week when its daylight to work on anything and i can't afford to have the truck down while i'm "trying" to fix it. thanks for the help
LR
Old Dec 4, 2002 | 06:08 PM
craterjoe's Avatar
craterjoe
that would be the other option of course....
good luck let us know how it turns out!
craterjoe
Old Dec 4, 2002 | 06:20 PM
samhihn's Avatar
samhihn
And...if you've got tilt steering.don't smack the bolt with a hammer!
Old Dec 4, 2002 | 06:48 PM
Mikeman's Avatar
Mikeman
bust7015
Jan 20, 2015 01:36 PM
ford country boy
Nov 30, 2014 03:24 PM
Vrybusy
Jul 24, 2011 05:29 PM
R7d7ta
1997 - 2003 F150
Feb 20, 2011 01:14 PM
scottlane13
Nov 2, 2010 07:06 AM
