Just won't start!
Old Jul 20, 2011 | 09:38 AM
ARMORER's Avatar
ARMORER
Just won't start!
Hello all,
My '94 F150 with the EFI 4.9 has always run like a champ. Recently, I started it up, and it drove about 1/4 mile and just died. I havn't been able to get it started again. I put in a new cap,rotor, and fuel filter. It's getting spark, and it's got plenty of fuel pressure at the rail. If you spray ether into the intake, it will sputter, and run breifly on what seems to be 1 or 2 cylinders. What on earth is going on? I even replaced the electronic ignition module on the driver's side wheelwell, to no avail. Any ideas?
Thanks!
Old Jul 20, 2011 | 03:52 PM
f100jim's Avatar
f100jim
And the ECU error codes are........?
Old Jul 21, 2011 | 09:22 AM
ARMORER's Avatar
ARMORER
It is surprisingly not throwing any codes!
Old Jul 21, 2011 | 09:31 AM
ARMORER's Avatar
ARMORER
That's actually why I'm starting to suspect that the ECM itself is shot. Does that ever happen? Where the whole thing just fries with no warning? The fuses are all good, I already checked those.
Old Jul 21, 2011 | 11:11 AM
Truckin Bob's Avatar
Truckin Bob
Well, yes the ECM's do sometimes develop problems.
Here's a link for some information for you to check out.
A9x ECM's (and same years ECM's) Failures Due to Age
The ECM's discussed are Ford but for (I think) Mustangs.
I did this repair and it cured a progressivly worsening miss problem I had.
Check it out and good luck.
Bob
Old Jul 21, 2011 | 11:14 AM
f100jim's Avatar
f100jim
I'm far from an expert on the EFI system. I wonder if there are "stored" codes (codes that remain until cleared) and "temporary" codes (codes that go away when the key is turned off.
If you have good fuel pressure at the rail, and you have spark, it sounds like your injectors are not firing. Could be a bad ECM or a bad electrical connection in the injector wiring.
I doubt it is something like crud blocking the injectors because it would be unusual for it to happen all of a sudden on all 6 injectors, unless something really drastic happened.
Old Jul 21, 2011 | 05:32 PM
coolguy1419's Avatar
coolguy1419
I don't know if this will help. But under the dash there is a fuel safety shut off. It is like a little red button. Possibly it popped up and is shutting fuel off to the motor. You might check that and see. I know sometimes when a front end impact occurs that valve pops up and shuts off fuel. I would check and see.
JW1971
1978 - 1996 Big Bronco
Nov 19, 2014 11:09 PM
JW1971
Nov 12, 2014 10:16 PM
billingslm1
May 29, 2013 07:38 AM
cyclist7531
1983 - 2012 Ranger & B-Series
Apr 29, 2011 11:22 AM
KevinE350
Jan 11, 2011 06:24 AM
