64 front suspension
Old Jul 19, 2011 | 10:27 PM
Andrew Green's Avatar
Andrew Green
64 front suspension
I'm going to update my front suspention by replacing the crossmember and putting a IFS package. 1. I saw a couple options for IFS and steering packages on Helix and would like a couple other sources for parts. 2. I see everyone who does this boxes in their frame, I think for support? 3. Has anyone else done this and has advise and or pictures? Thanks
Old Jul 19, 2011 | 10:51 PM
514strokerF100's Avatar
514strokerF100
64 F100 FRONT SUSPENSION MOD
HEY I HAVE PUT HTE CROWN VIC SETUP ON MY TRUCK EASY SETUP AND THE COMPLETE SUSPENSION K-MEMBER AND ALL IS SO LIGHT I CARRIED IT TO MY TRUCK MYSELF
Old Jul 20, 2011 | 08:24 AM
Andrew Green
You wouldn't have and pictures by any chance would you. Just trying to get a feel of all my options before I start the project.
Old Jul 20, 2011 | 10:14 AM
429unibody's Avatar
429unibody
I did the Aerostar swap in my 61 there is 2 albums of my swap in my albums ,go to my profile and you can check them out
Old Jul 20, 2011 | 10:33 AM
514strokerF100
TRYING TO GET ANOTHER CAMERA PICS IN PHONE NOT GOOD THOUGH, SAW A TREAD ON THIS SWAP JUST WASNT SURE IT COULD HANDLE THE WEIGHT OF MY SETUP PLUS THIS INSTALL IS PRETTY MUCH BOLT IN, BESIDES THE TUBES FOR THE BOLTS BOX PLATES FOR EXTRA STRENGTH AND 2 BRACKETS FOR THE ARMS THAT CAN BE WELDED OR BOLTED WILL POST PICS SOON
Old Jul 20, 2011 | 10:54 AM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
You can also do the Jaguar clip swap. Its similar to the CV swap if a few key ways. Namely in that it is a K-member, and can almost just be bolted in.
It allows 15 inch rims, a 4 inch drop stock, near stock track width, and decent disk breaks.
Old Jul 20, 2011 | 11:24 AM
Andrew Green
I was thinking of putting on a double wish bone suspention with an new crossmember. Is there an advantage to the k member other than its bolts on?
Old Jul 20, 2011 | 01:23 PM
Ziegelsteinfaust
Not really any big difference I am aware of with out seeing the competing set-ups.
The CV is a heavy car thusly suited to light duty trucks such as a F150.
The Jag is no light weight, and offers decent breaks for cruising/light work.
Old Jul 21, 2011 | 12:23 AM
514strokerF100
TO REPLY TO YOUR QUESTION ARE THEIR ADVANTAGES TO THE CROWN VIC SETUP, THERE ARE, LARGE ROTORS DBL PISTON CALIPERS AND ALL PARTS DESIGNED FOR THE WEIGHT OF A HEAVIER MOTOR AND THE STOPING CAPABILITY ALSO, ITS AND ALL FORD SETUP WITH A LARGE SELECTION OF PARTS THAT WONT BREAK THE BANK OR BE HARD TO AQUIRE, ANY PART FACT. ITEM CAN BE PURCHASED AT YOUR LOCAL AUTO PARTS OR BONEYARD AND THE BOLT PATTERN AFORDS A LARGE SUPPORT OF GREAT LOOKING WHEELS ALL SIZES CHEAP
Old Jul 24, 2011 | 04:13 PM
CTom's Avatar
CTom
If you look in my "album" pictures I have a few shots of the CV set we installed........
Good luck.
Robber80
2004 - 2008 F150
46
Mar 26, 2018 07:14 PM
Strokin-A-2010
Nov 1, 2016 08:12 PM
snelldawg
Oct 26, 2016 05:39 AM
Unrealo4
6.7L Power Stroke Diesel
Sep 22, 2014 11:55 AM
Trader Bob
Jul 8, 2003 11:03 AM
