looking for input
Old Jul 21, 2011 | 11:43 AM
Talyn's Avatar
Talyn
Originally Posted by arkredneck
If you have the aeroforce scan gauge you could compare its boost to your boost gauge
if his map sensor isn't reading right, its just going to guess.
When my map sensor went bad, it was right on with my boost gauge still, even while guessing.
But still not a bad idea.
Old Jul 21, 2011 | 04:39 PM
rideracelivemx7's Avatar
rideracelivemx7
William what did your truck do when your map was bad? First we thought it was am over boost kind of deal and fuel cut but I dint believe that's it. Zero fluctuation on ipr and icp. I'll try the map sensor though thanks.
Not sure if I said it yet but I have a diablo chip I'm there now just fpr testing and my truck is Ibcredibly fast. Faster than the dp as it was and it doesn't have the cut out and I get about 25-26lbs of boost. Very low smoke. For a generic tuner it hauls! But it gets very hot so I keep goofing off to a minimum. Not as fast as it was with the dp and engine light on.
Old Jul 21, 2011 | 04:40 PM
rideracelivemx7
And yes all this is at full temp, I don't like tp mess around till she's warmed ul
Old Jul 21, 2011 | 07:19 PM
arkredneck's Avatar
arkredneck
If you lived in Arkansas i got 3 trucks we could swap parts and figure out if it's a map sensor
Old Jul 21, 2011 | 08:12 PM
rideracelivemx7
just swapped with my buddy, no dice and same results. UHG! getting annoying. what is it about these dang diablo chips that make these trucks run good lol the drivability of the truck is awesome and spools very fast. makes me almost want to keep running it but its crap tuning sketchs me out. weird off idol and hot egts! i just want my dp to work right
Old Jul 22, 2011 | 11:24 AM
Talyn's Avatar
Talyn
Yeah, my truck was acting like that when bad.
If you swapped them and still had same issue, then I duno.
Zejokee
May 19, 2014 12:44 AM
countrycar
Nov 21, 2012 07:16 PM
cyco
Sep 24, 2012 09:53 AM
strokin'_tatsch
27
Apr 3, 2010 06:39 AM
SuperDoodie
16
Jun 28, 2008 10:40 PM
