Spindle end-cap thread repair
Old Jul 18, 2011 | 03:41 PM
Wes66's Avatar
Wes66
As a new member, I want to say hello to you all and thank you for your postings. I have been using the info to begin the process of fixing up a neglected 1966, F250 Camper Special, 2wd, 4 drums, 352 engine that I got from a friend who followed a job opportunity outside the country. My goal is not to restore it to show quality but to make it a decent looking, reliable truck - which is going to take a lot of work.
What is the tap size for the grease cap spindle threads at the end of the spindles? I am replacing the king-pins and noticed that the threads on one end are damaged at the start probably due to a PO pounding on it with a hammer to remove the king pin. One macnine shop said I needed to special order a 1-1/16, 18 tpi bottoming tap. Another shop thinks its 20 tpi (threads per inch). I would appreciate knowing the corect size before springing the $s.
Old Apr 22, 2012 | 01:42 PM
wyazel1's Avatar
wyazel1
In the process of removing my old kingpins I damaged the threads for the grease caps. Does anyone know what size tap to buy to reapir those threads????
Old Apr 22, 2012 | 02:27 PM
Wes66's Avatar
Wes66
1 and 1/16 inch diam, 18tpi. Its an expensive one, I will let you borrow mine if you want.
GregN
Oct 3, 2025 03:53 PM
ROADHOGE250
Mar 24, 2019 06:55 PM
Corn Fed
WTB - Parts & other
Feb 28, 2017 10:52 AM
jeff2011
Sep 7, 2009 10:54 PM
PhilfromFlorida
Apr 2, 2008 03:50 PM
