Sponsored by: Real Truck
front end clunk
Old Jul 18, 2011 | 01:18 PM
rockcrawler_101's Avatar
rockcrawler_101
front end clunk
I have a 01 ford superduty with 7.3l and a 5.5 inch fab tech lift on 37's. It has got a clunk in the front passenger area when I turn it will clunk one way and then when I turn the other way it will clunk back. But if you turn the same way it doesn't clunk multiple times. It has new ball joints and I have jacked it up and pushed on the wheels to check for any play and don't get anything. I have looked at the track bar while someone moves the steering and see no play. I removed the sway bars and the clunk is still there. I think its either the track bar or a wheel bearing but both look fine when working on it but when driving it clunks. I have rechecked all the bolts in the lift kit and there fine. Checked the lug nuts too.
Old Jul 18, 2011 | 05:42 PM
rockcrawler_101
To the top. Any ideas?
Old Jul 18, 2011 | 07:26 PM
wayfastwhitey187's Avatar
wayfastwhitey187
i have the same issue with mine so if anyone can shed some light itd help two people out
Old Jul 18, 2011 | 07:48 PM
Firemudder's Avatar
Firemudder
Look at the swaybar link bushings. They tend to go out. Might also be the ball joints. Some guys have gone out very quickly.
Old Jul 18, 2011 | 08:19 PM
rockcrawler_101
New ball joints and took sway bar off and still makes the noise
Old Jul 18, 2011 | 08:54 PM
Firemudder's Avatar
Firemudder
Check the body mounts. Also could be the leaf springs.
Old Jul 18, 2011 | 08:58 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
All of the above. Also, check you hubs. One (or both) of my auto lock hubs is stuck locked. I am going to fix it in a week or so.
Old Jul 18, 2011 | 10:31 PM
rockcrawler_101
Its got new leafs but the body mounts is a good idea will look into that. Will double check the hubs to didn't really look at those to close
Old Jul 18, 2011 | 11:00 PM
ak-angler's Avatar
ak-angler
Check your shock mounts, too. And don't be afraid to put a pry bar on the track bar, ball joints, tie rods, shock mounts, etc.. Sometimes things look OK and you can't move them by hand, but the added leverage of a pry bar can help pinpoint loose parts.
Old Jul 19, 2011 | 02:56 PM
351Cleveland C4's Avatar
351Cleveland C4
same problem here,, 4" lift and 35"tires .. but mine only does it when i hit a bump turning an low speed. 10mph. i think its just the front spring pack moving again. theres 10 leaves on each front pack and i think that clunk is just them breaking loose and flexing.. but if anyone comes up with another reason im all ears...
Old Jul 19, 2011 | 03:07 PM
351Cleveland C4
theres also another clunk that comes to mind. when you dont get the hubs fully engaged before puting down the torque. (like holding the brake on a hill while pulling a trailer and having someone lock the hubs) if the hubs arent fully engaged theyll be a veryloud clunk when you try to go again. (this has happened to me a couple times and now i know not to do it this way.)but this is an entirely diferent clunk
Old Jul 19, 2011 | 03:31 PM
rockcrawler_101
Noticed the rear bushing on the passenger side on the leaf (where the clunk sounds like its coming from) the leaf has shift on the bushing and is almost touching the shackle.
Old Jul 25, 2011 | 06:41 PM
351Cleveland C4
mine is like that too,, i dont seem to have a problem with it. clunk is definatley from the front on mine
Old Jul 25, 2011 | 07:42 PM
rockcrawler_101
Turned out to be the leaf spring bushing. Looked good from the outside. Pulled the leaf out and the bushing just fell out.
Old Jul 26, 2011 | 01:16 AM
ak-angler's Avatar
ak-angler
Glad to hear you found the problem. Be sure to post your results when you get the bushing swapped out.
ycis
May 22, 2014 11:56 PM
Diesel Submariner
Nov 4, 2012 11:44 PM
X JBM X
33
Aug 28, 2010 08:19 PM
transamman78
Nov 17, 2008 09:44 AM
bokker
1997 - 2003 F150
18
Jul 30, 2008 10:39 AM
