1994 F150
Old Jul 18, 2011 | 11:50 AM
Bigmonts's Avatar
Bigmonts
1994 F150
Hello, I have a 94 F150. When I run the A/C especially max air the motor will start to drop down to passing gear, back and forth fairly often. It will do it at low speed and still do it at 55mph. It is a 5.0. Any sugestions?
Old Jul 18, 2011 | 03:06 PM
Brad Felmey's Avatar
Brad Felmey
Sounds like the thingy that bumps up the throttle when the compressor engages is horribly misadjusted or malfunctioning.
Old Jul 18, 2011 | 05:40 PM
TexasGuy001's Avatar
TexasGuy001
The 5.0 often goes to passing gear anyway when the AC is on it is more frequent. Its because the factory gearing is not matched to the engine.
How long have you had the truck? If this is something you just noticed then there could be a problem. If its done this since you have had it, then it is likely the nature of the truck.
84f150guy
123
Oct 15, 2011 05:47 PM
Jaysch44
1997 - 2003 F150
May 28, 2009 01:43 PM
albung
Mar 24, 2007 04:30 PM
stixx06
1997 - 2003 F150
Aug 28, 2006 08:33 AM
Nahum
Oct 12, 2003 11:25 PM
