Sponsored by: Innova
2009 expedition audio wiring color code
Old Jul 17, 2011 | 11:55 PM
89foxGT's Avatar
89foxGT
Does anyone have the color code for the wiring on my nav/stereo unit? I have the nav unit with sync.
Thanks
Old Jul 19, 2011 | 04:04 PM
ReAX's Avatar
ReAX
Closest I could find
#513820: 2008 FORD F150 2DR TRUCK WITH 4.2L ENGINE AND STANDARD AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery LIGHT GREEN/VIOLET (+) RADIO HARNESS
Accesory LIGHT GREEN/YELLOW (+) RADIO HARNESS
WILL BE PINK/BLACK ON XL AND STX MODELS.
Ground BLACK (-) RADIO HARNESS
Illumination LIGHT BLUE/RED (+) RADIO HARNESS
LF Speaker (+) ORANGE/LIGHT GREEN
LF Speaker (-) LIGHT BLUE/WHITE
RF Speaker (+) WHITE/LIGHT GREEN
RF Speaker (-) DARK GREEN/ORANGE
LR Speaker (+) GRAY/LIGHT BLUE
LR Speaker (-) TAN/YELLOW
RR Speaker (+) ORANGE/RED
RR Speaker (-) BROWN/PINK
Steering Cntrls OPTIONAL
Speed Cntrl YES
Radio Security YES
Security
Battery LIGHT GREEN/VIOLET (+) IGNITION SWITCH HARNESS
Ignition 1 BLUE/LIGHT GREEN (+) IGNITION SWITCH HARNESS
Starter 1 RED/LIGHT BLUE (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/LIGHT BLUE (+) AT VEHICLE LIGHT SWITCH HARNESS
Domelight Super BLACK/BLUE (+) AT VEHICLE LIGHT SWITCH HARNESS
LF Latch BLACK/YELLOW (-) AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
PIN #4
RF Latch BLACK/PINK (-) AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
PIN #5
Parking Lights BROWN (+) AT VEHICLE LIGHT SWITCH HARNESS
Convenience
Headlights-Lo RED/YELLOW (+) AT VEHICLE LIGHT SWITCH HARNESS
Wipers-Lo BLACK (-) AT VEHICLE WIPER CONTROL SWITCH
Parking Brake LIGHT GREEN/RED (-) AT VEHICLE PARKING BRAKE SWITCH
Seat Mem 1 BROWN/LIGHT GREEN (-) AT SEAT MEMORY SWITCH
Seat Mem 2 BLACK/ORANGE (-) AT SEAT MEMORY SWITCH
Remote Start
Accessory 1 BLACK/LIGHT GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLACK/PINK (+) IGNITION SWITCH HARNESS
Neutral Safety PINK/LIGHT GREEN (-) AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
PIN #46
Tachometer TAN (AC) PCM MODULE ON PASSENGER SIDE FIREWALL
PIN #52
Crankshaft Sensor GRAY (-) AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
PIN #46
Camshaft Sensor DARK GREEN (-) AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
PIN #45
Speed Sense GRAY/BLACK (-) AT PCM MODULE ON PASSENGER SIDE OF FIREWALL NEAR BATTERY
PIN #63
Brake Lights GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights BLACK/PINK (+) IN HARNESS IN DRIVER KICKPANEL
Horn DARK BLUE (-) IN HARNESS AT STEERING COLUMN
Anti Theft RX GRAY/ORANGE
Anti Theft TX WHITE/LIGHT GREEN
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock PINK/GREEN (-) AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
PIN #1
PowerLock PINK/YELLOW (-) AT BCM MODULE BEHIND TRIM IN REAR OF CAB ON DRIVERS SIDE
PIN #9
Driver Mtr Unlock RED/ORANGE (AC) AT MOTOR IN DOOR
Driver Mtr Lock PINK/BLACK (AC) AT MOTOR IN DOOR
Pas Mtr Unlock PINK/ORANGE (AC) AT MOTOR IN DOOR
Pas Mtr Lock PINK/BLACK (AC) AT MOTOR IN DOOR
LF Window Up TAN/LIGHT BLUE (REV) AT DRIVER WINDOW CONTROL SWITCH
LF Window Dn WHITE/BLACK (REV) AT DRIVER WINDOW CONTROL SWITCH
RF Window Up TAN/LIGHT BLUE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RF Window Dn WHITE/YELLOW (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
It's a decent place to start.
CobraBuilder
Jan 6, 2017 03:59 AM
Criegg
Oct 26, 2015 07:46 PM
mtnxtreme
Sep 12, 2015 06:54 AM
Scottay
Oct 20, 2013 04:38 PM
st381
May 25, 2010 01:24 PM
