Trans pump seal/bushing install question
Old Jul 17, 2011 | 11:04 PM
Buicksx2's Avatar
Buicksx2
Hi All,
First off many thanks for this board and help from everyone.
Couple weeks ago I posted about pump seal going and with a tow to Ohio next week with race car and no maintenance records on this truck I am taking the advice of more experienced PSD owners.
I ordered and mounted my tru-cool 4739 and this week dropping trans at buddys shop and replacing pump seal and bushing.
Any advice or tips for replacing both of these? Truck is getting new fluid and filter while trans is out. Where does the bushing go? I assume the pump has to come out to do the bushing, while the seal goes on straight after old seal taken out?
Sorry for the stupid question but if it's a Buick Grand National I'd know where everything goes as I have been around them for the past 24 years.....lol.
I thank everyone on here for your help as this board has been a tremendous asset to me and my learning curve of the PSD.
Thanks
Rich
Old Jul 17, 2011 | 11:57 PM
mueckster's Avatar
mueckster
Bushing and seal go in the pump front housing. Be sure to orient the lube groove in the same position as the one removed. You will need to separate the pump to remove and install the bushing. The two sections must be aligned correctly upon reassembly and torquing of the bolts. A large clamp is needed around the circumference of the pump to ensure the halves are aligned. I also used two snug fitting bolts or pins in the pump mounting bolt holes to keep the holes aligned.
Name:  pump (exploded view).gif
Name:  pump bushing.gif
Old Jul 18, 2011 | 07:27 PM
Buicksx2's Avatar
Buicksx2
Roland,
Thank you very much, this is why I love this board, with that diagram you went above and beyond and that will make the install much easier.
I thank you again.
Stay well,
Rich
Old Jul 18, 2011 | 09:51 PM
mueckster's Avatar
mueckster
My pleasure, Rich. I enjoy helping out my brothers (and sisters) when I can.
Old Jul 18, 2011 | 10:05 PM
Buicksx2's Avatar
Buicksx2
Thanks again Roland......hopefully by weeks end new seal and bushing will be in, with fresh fluid and hook up my Tru Cool and we are off to drag race next week in Ohio
Old Jul 18, 2011 | 10:29 PM
mueckster's Avatar
mueckster
Do you have a shift reprogramming kit, such as the TransGo Tugger, already installed? If not, this would be a good time to do it. While the pump is out and apart, you can do the mods to it.
Old Jul 18, 2011 | 11:12 PM
Buicksx2's Avatar
Buicksx2
Hi Roland,
No I don't I just have the stock trans, probably would be a good idea but I am just back to work after being out for 2 years due to a corporate downsizing. So all my hobbies have taken a back seat, if I had some extra cash I would do it. What exactley does the Trans Go Tugger do?
I tow to Ohio twice a year, Maryland a couple times, the rest of the time the truck sits or I use for for Home Depot runs and honeydo's.....lol.
Old Jul 18, 2011 | 11:27 PM
mueckster's Avatar
mueckster
The reprogramming kit would improve shift quality by raising pressures where needed and speed application of the clutches to reduce slippage. The pump mods help to improve overall line pressure and that of the torque coverter clutch application. All these things will help to reduce heat in the trans and increase trans life. The kit averages around $100 and is well work the cost.
Old Jul 18, 2011 | 11:31 PM
Buicksx2's Avatar
Buicksx2
Roland,
How long to do something like that and can a extremely average mechanic like me do it? How hard is it to install and how good are the instructions?
Thanks
Old Jul 19, 2011 | 08:23 AM
mueckster's Avatar
mueckster
That would be kind of hard for me to determine. I would give yourself a full day to R&R the trans and do all the mods. The instructions are pretty straight forward. There would be a couple of mods in the kit that wouldn't be done unless you tear into the trans further than the pump. When removing the pump to replace the bushing and seal, you will need the large O-ring that goes around it and the gasket behind it. There are also 2 sealing rings on the rear and 1 on the front of the stator shaft (ring grooves are #38 & #39 on the exploded view) that I would consider changing while out and can be difficult to get to compress as the pump is installed. You can get a rebuild gasket kit that has all the seals, rings, and gaskets necessary for the job. You may just have to purchase the bushing separately.
I hope this answers your questions and if you have any more, just let me know.
Old Jul 19, 2011 | 07:16 PM
Buicksx2's Avatar
Buicksx2
>>> Hi Roland,
The plan is to devote a whole day at my buddys shop. I know he ordered a gasket kit from the dealer and it has the O ring gasket and and the gasket behind it as well as the pump seal.
I really don't want to tear into the trans anymore than just dropping it, removing pump and doing the mods of the Transgo Tugger.
So based on what you said above we can just mod the pump when we take it apart and not go further into the trans?
Besides dropping trans and doing these mods we are running lines to the tru cool I mounted over the weekend and put it back up and then fill with fluid and take her for a drive and hope all goes well because next thursday we are off to Ohio.
Thanks again Roland I appreciate all your help on this.
Old Jul 19, 2011 | 11:46 PM
mueckster's Avatar
mueckster
Originally Posted by Buicksx2
>>> Hi Roland,
Yes. Most persons who install the TransGo Tugger kit do not remove their transmission. Therefore, they do not get the advantages of the pump mods or some other apply piston upgrades. IMHO, Not installing the remaining upgrade parts won't necessarily mean that those areas will fail. They were simply designed to reduce or eliminate the risk.
Da_Lariat_Chariot
Aug 1, 2017 07:19 PM
BossFan
709
May 24, 2017 03:08 PM
BadDogKuzz
26
Jun 7, 2015 09:55 PM
geoaigel
Aug 18, 2011 05:42 AM
sixgunner
1997 - 2003 F150
Dec 11, 2008 12:05 AM
