Modular V10 (6.8l)
Ford Scorpio V10
Old Mar 30, 2003 | 01:53 PM
CountCossie's Avatar
CountCossie
Ford Scorpio V10
Hello everybody.
I got a radical idea that's been brewing inside my head for quite some time now.
Fitting a 6.8l V10 in a European Ford Scorpio.
Do you guys know of any site where I can find technical information about this engine? I don't know the engine very well, so I have to learn more about it..
How easy is it to get hold of damaged vehicles in the US? Shipping to Europe? I obviously don't need the entire car, only the engine, transmission, and drivetrain.
Do you guys know how heavy it is? How BIG it is..?
Also, do you know of anyone who has Supercharged the V10?
If I'm not totally mistaken it comes with a auto-tranny, any manual gearboxes that are bolt-on..?
Nicolai Isaak Stubbrud - Norway
Old Mar 31, 2003 | 08:24 AM
Fredvon4's Avatar
Fredvon4
Ford Scorpio V10
Check out this thread,
Welcome from the U.S. !!!
The V10 wieghs about 640LBS/ 1408KG
The auto trans is LONG and you would need a drive shaft/rear end that would handle all the torque
Besause the V10 is longer than wide and the length of the transmission, I think you would have a lot of problems stuffing the entire power train into such a small wheel based auto like the Scorpio. Also the weight will cause you much grief trying to find a set of springs to keep the front off the ground.
Lastly any number of small V8 "crate" motors can be purchased with HP from 225 up to 600 and be much easier to get shipped to Europe.....
In the long run you would be better off spending all that money on making the current Scorpio motor a serious HP machine as today the choices are only limited by the amount of money you have to spend.
http://www.powertechengines.com/100.html
Old Mar 31, 2003 | 09:42 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Ford Scorpio V10
That's a HEAVY engine! 1408KG = 3098 pounds!
I think you had your conversion backwards. 640 pounds = 291 Kg.
Old Mar 31, 2003 | 12:49 PM
Fredvon4's Avatar
Fredvon4
Ford Scorpio V10
Mark absolutly right! My bad I hit the * instead of the / key and did not stop to evaluate the answer... good catch
Sorry to anyone who was amazed at the EXTREEM weight of the V10
Old Mar 31, 2003 | 03:21 PM
CountCossie
Ford Scorpio V10
I imagine that I will have to change the gearbox.
I want a 6-speed manual box anyway... I think a Borg Warner would do quite nicley.
The V10 is a 20 valver right..?
I think that if they can fit v12's in BMW 3-series I can fit a v10 in a Scorpio. I may be difficult, but that only makes it more interesting!
Old Mar 31, 2003 | 03:24 PM
CountCossie
Ford Scorpio V10
By the way... Does it have a solid rearaxle, or independent?
Old Apr 3, 2003 | 07:21 PM
rabidsnowmobiler's Avatar
rabidsnowmobiler
Ford Scorpio V10
Ford does offer a 6-speed manual for the V-10, but I imagine it wouldn't fit your application very well. The 1st gear is a big time granny gear, and would be pretty much worthless in a Scorpio. I believe the tranny is made by ZF.
The V-10 is a 20 valver (one intake and exhaust valve per cylinder)
All vehicles that Ford puts the V-10 in have solid rear axles.
If you are still serious about this endeavour, there is a V-10 on ebay right now. I am not sure if you will be able to bid on it from Norway though. Good luck!
Old Apr 4, 2003 | 07:19 PM
birdman127's Avatar
birdman127
Ford Scorpio V10
Welcome to the board and to the USA!!! Good Luck on your conversion
Old Apr 5, 2003 | 09:47 AM
OGNOM's Avatar
OGNOM
Thumbs up Ford Scorpio V10
Welome Welcome to the site. Go for it CountCossie, everything is possibile. I stuck a LT1 350 W/ 400 trans in a 76 Chevette in 77'. Keep us updated
Old Apr 10, 2003 | 11:59 AM
Fredvon4's Avatar
Fredvon4
Ford Scorpio V10
I know that I have been a stick in the mud on this one, but I should give some background..
Did the V8 in a Vega 1978 (never could keep the car on a corner)
Stuffed a Blazer chassis under a Caddy Fleetwood in 1982 (most bitchin 4X4 in the State (Texas)
Stuffed a 289 V8 in a German Ford Taunus in 1984 (drag racer in Hanau Germany...FAAAAAST!!
Put a Kawasaki 900cc 4Cy on the back of a go cart...(fastest 4 wheels on the planet)!!!!
Just out in the parking lot looking under the hood because of a mod that Stan wright had done, and I saw the biggest reason that the Triton V10 will not go in a Scorpio...
The hight of the engine from air intake down to the bottom of the oil filter seems to be VERY deep, no tape with me, but I estimate al least 3 feet!!
I say again, it looks like my motor on the drivers side is at least 3 feet tall from the bottom of the oil filter to the top of the air inlet, go look for your selves and see if I am all wet.
Old Oct 25, 2004 | 08:32 AM
CountCossie
3 feet huh... Jeez... That's big... Is that to the top of the original inlet manifold?
I could build a new inlet of course.. how tall is it from the bottom of the sump to the top of the headcovers? It is a 60 degree V10 right? This smells of a Custom bonnet..
rabidsnowmobiler: do you the full name of that gearbox? At which ratios? I imagine i could use a 9" motorsport diff from a Sierra Cosworth. It should take some battering.. Or maybe a Quaife ATB. They're also known for handling Cosworth's pushing out up to 750 BHP..
Is the V-10 a pushrod engine or a OHC?
Old Oct 25, 2004 | 10:18 AM
hang10's Avatar
hang10
That's funny. I did the exact same thing, except I used a Kawasaki 750 turbo. Oh yeah, it was fast.
Old Oct 29, 2004 | 11:08 AM
lr's Avatar
lr
Where would be a good place to find the dimensions on the v10 and also the zf 6spd. I've been looking for a replacement motor for my truck (1989 f250 4x4) and would like to atleast consider the possiblity of putting a v10 in it before i spend the money on a remain 351. also the local salavage yards seem to have a couple low mile 200ish models laying around for not to much more than a qualty rebuild.
thanks
Larry
Old Oct 29, 2004 | 01:21 PM
Fredvon4's Avatar
Fredvon4
I think it is funny how we have resurected this very old thread three times.
Larry
I lost my link when changing from Win 98 to Win XP so you will have to do a google search. There is a lot of that kind of info for all the Modular Ford motors out on the web.
Retro fitting a pre 99 V10 may be possible, I don't know much about the early motors and their controls. I do know that a 1999-2004 V10 w/ZF 6sp into your 89 Pickup will be a royal PITA. Nobody makes adapter kits so the physical placement will be totaly up to you for fabrication. But the bigger problem is fuel and electrical interfacing with your truck.
These are computer controlled motors and the Power Control Module (PCM) requires signals from the Auto trans (if equiped), Fuel system, brake system (ABS if equiped), vapor system, Vehicle speed sensor (VSS(tone wheel on the differential ring gear)), the Air Bag system, and seat restraint system. Many of these can be eliminated or fooled but it is a real pain to get the info on what wire wants what signal level and duration.
Just getting the whole wiring out of donor truck will drive you nuts and don't forget that most all the instrument cluster signals on the V10 donor truck come from the PCM.
For the time money and effort you will be happier and faster with a good hopped up crate motor and associated go fast goodies.
The V10 is a torque maker but still only 295-310 HP at 415cubic inches. Many crate motors make better HP and torque for $3700-$8000 and are bolt in swaps.
Old Oct 29, 2004 | 03:43 PM
lr's Avatar
lr
Fredvon4,
Thanks for the info. I figured that would probly be the case but i just couldn't pass on the idea without doing some investigation. I've been looking into the crate motors but i've not found one that i've liked yet.
thanks
Larry
