Modular V10 (6.8l)
Ford Scorpio V10
Old Oct 29, 2004 | 09:46 PM
DJR 17's Avatar
DJR 17
Originally Posted by CountCossie
Is the V-10 a pushrod engine or a OHC?
OHC, this aint no chebby!
Old Oct 31, 2004 | 12:10 AM
73Fastbackv10's Avatar
73Fastbackv10
F.Y.I. the v10 weighs just about the same as the old 5.0s, so it's not some overly large engine. The most difficult parts of the swap are the width of the v10 and the height. I'll post the specs tomorrow as I have 2 v10s in my garage and don't want to put my shoes back on tonight.
Old Nov 1, 2004 | 07:16 AM
RTM's Avatar
RTM
I saw a ford capri or pictures of one with a V10 in it. My buddy has the link or did. he is the one that found it. I will see if he still has the link or can find it again. the capri is like the 79 and up mustang car.
Old Nov 2, 2004 | 03:07 PM
73Fastbackv10
Okay, the v10 is 31" wide at it's widest points and roughly 36" tall from the bottom of the oil pan to the top of the plenum.
The link RTM is looking for is: http://twin-turbo-v10-mustang.envy.nu/home.html
Old Nov 2, 2004 | 04:18 PM
CountCossie's Avatar
CountCossie
The link is bad.. There file is not found..
Otherwise, thanks for the info! A Capri with a v10 you say..? Nice... I definitely need some info on that.
Old Nov 2, 2004 | 06:27 PM
RTM's Avatar
RTM
The link didn't work for me either.
Old Nov 2, 2004 | 07:03 PM
73Fastbackv10
Darn, that used to be his homepage. He was some Joe Dirt looking guy from the east coast. He had plans to twin turbo his v10 by putting the exhaust manifolds on backwards. I'll see if I can contact him through modfords. Sorry guys.
Old Nov 2, 2004 | 07:06 PM
73Fastbackv10
This should be it: v10 capri
Old Nov 9, 2004 | 02:20 PM
ken04's Avatar
ken04
Originally Posted by lr
Where would be a good place to find the dimensions on the v10 and also the zf 6spd. I've been looking for a replacement motor for my truck (1989 f250 4x4) and would like to atleast consider the possiblity of putting a v10 in it before i spend the money on a remain 351. also the local salavage yards seem to have a couple low mile 200ish models laying around for not to much more than a qualty rebuild.
thanks
Larry
For $4,000-$8,000 you can buy a Ford Motorsports 514 big block, or a 450+ cu inch small block 5.0 that will make 400-600+hp out of the box. It will also bolt right in your F-250 and you tranny. You will spend triple that to convert a V-10 and have less, why do it ? If you're one of those guys who love that kind of challenge more power to ya. I do not have that kind of patience or those engineering skills needed. With the overabundance of good crate engines out nowadays that are built with correct parts and the cheap prices it's almost cheaper to replace rather than rebuild. Check into it, you may be surprised, Ken
Pablo-UA
Aerostar
May 4, 2007 12:00 AM
madclone
Bronco II
Jan 9, 2006 06:50 AM
Little_E
Jan 22, 2005 10:29 PM
