460 Engine types and list
Old Jul 31, 2011 | 12:12 PM
meborder's Avatar
meborder
Originally Posted by jpierce1977
i own a 76 f150 2wd with 390 bone stock but the daul exht and i have not found anything that has cause it to be bad at hauling and i have had some big loads on it 3500 lbs of shale made it sit on the stops but pulled out in drive up hill not a guess at that was on scales and if you do the swap you will need alot engine, mounts, exht,bell houseing,clutch,acc brackets ,and that is just to start it depends on witch 460 you use as a swap i am doing a swap from a 400 to 460 on a 4x4 witch is not that bad same engine familey so if i was you let it alone but if you are looking for power they make strocker kits and stuff for the 390 well good luck with it
Wheeeww !!!
I don't know about you guys ... but I'm exhausted!
stuman
New Member Introductions
Sep 27, 2021 11:02 PM
74f100sc
15
Feb 23, 2016 11:26 PM
Jnissen04
Aug 7, 2011 01:38 AM
Blackfoot Big Block
13
Dec 8, 2009 09:27 PM
Unimog005
22
Apr 6, 2007 07:26 PM
