Stud Extractor suggestions?
Old Jul 6, 2011 | 03:10 PM
FordmanShane's Avatar
FordmanShane
has anyone broken the head off a nut, i did last week and i got less then half an inch sticken out.. i was thinking about this using this 3/8" Dr. Universal Stud Extractor Neiko Tools, New - eBay (item 300512782492 end time Jul-06-11 20:53:25 PDT)
Old Jul 6, 2011 | 03:27 PM
jim collins's Avatar
jim collins
Where is it broken? Is it on something that heat won't hurt and are you a good welder ? If so you may be able to weld a nut on it and the heat may help it break loose when you put a wrench back to it.You can drill in to it with a smaller hole and use a easy out tool,i did one the other day that way. I don't know anything about the tool you showed on ebay.
Old Jul 6, 2011 | 03:31 PM
ford1977owner's Avatar
ford1977owner
like what jim said about heating it up maybe if you have enough sticking out get a pair of vise grips and clamp down hard on it and try turning it out
Old Jul 6, 2011 | 03:37 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
And as alway's, PB Blaster goes well with everything.
Old Jul 7, 2011 | 10:59 AM
FordmanShane
The broken stub is on the block.. the bolt furthest to the right for the power steering pump plate... the plate is also warped
Old Jul 7, 2011 | 11:15 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
With that much sticking out you should be able to get it by welding a nut on and soaking. I threw away every EZ out in my garage. If you break it off you're screwed. If I can't get a bolt out, I'll drill and retap the hole.
Old Jul 7, 2011 | 01:00 PM
hevy metal's Avatar
hevy metal
If you can get a drill in there, try using a left hand drill bit and an easy out. I've had really good luck using that system, and if it doesn't work, you've already started drilling it out so you can re-tap it!
Old Jul 7, 2011 | 02:23 PM
FordmanShane
That was the first thing i try'd haha
Old Jul 7, 2011 | 09:39 PM
tomcasino's Avatar
tomcasino
I'm always extracting broken bolts where I work. If you can drill it, I like the suggestion of the left hand drill bit and extractor. Use a good one or you might be in more trouble if you break the extractor.
Old Jul 7, 2011 | 09:40 PM
ford1977owner
haha, well atleast im not the only one who has done it aha
Old Jul 15, 2011 | 09:38 PM
FordmanShane
I know its been a wile but I got around to it, a buddy of mine dropped off a welder, before i do anything I have to ask, im a novice when it comes to welding so work with me my plan is to weld a larger size nut over the broken bolt.. any safety tips? disconnect the battery maybe...
Old Jul 15, 2011 | 10:05 PM
FordmanShane
Could I ground the welder on my exhaust?
Old Jul 15, 2011 | 10:21 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I never have any luck with the weld trip, so before you get a mess of welding rod or wire gobbed on the broke off end, just center punch it and start drilling with a good set of bits.
Step up in bit sizes till you are all most at the bolt original diameter, then try a good easy out to remove the rest of the threads.
But if you buy a cheap one and it breaks off in there you will regret it, trust me on that call. So just step drill it then retap, if that does not work you can use a heli-coil if the tap part fails.
If the bolt is 9/16 there is a certain size drill bit to work up to, then a corresponding tap size. A little google research will get you the correct sizes to use.
Atleast its not a exhaust manifold bolt.....
Old Jul 15, 2011 | 10:32 PM
73 ford guy's Avatar
73 ford guy
Shane I'm a welder myself and can help you setup properly..
Whats the machine your going to use?
You should be fine with a ground to the exhaust
Old Jul 15, 2011 | 10:46 PM
Tsoptich's Avatar
Tsoptich
Your best bet, I think, with an easy out. Is to buy one that is good good quality. to be honest the best ones that I have used and bought were from carquest and harbor frieght. I have had one from snap on and the other tool trucks but they always broke and cost more to replace one or two then it is to buy a large pro set from the cheaper guys. Also didnt see this one suggested. If you got like 1/4 to 1/2 inch sticking out? get some vise grips and get the tightest bit and spray with P B blaster or such and wrench the F'er out. Good luck
