Temp ?'s
That stock fan pulls something like 7 horse power, it would be a large electric motor to move the same amount of air.
Back east with the humidity you can get by with less cooling capacity than you can in the west, for several reasons. It sorta depends on what you are doing and where you run the most.
You want to loosen the nut (LEFT HAND THREADS) before you loosen any fan belts.
I have seen several that came off especially when a rig was started and just drove a block or so, then shut off.
There are several grades of locktite, you can get some that is not hard to remove.
because:
That story makes me think it wasn't tightened correctly.
i do agree with your friend about the electric swaps though.
did you know,like myself,Dave S had great success (besides being that,he got failure prone fans.which i discuss in the link in my sig) running E-fans?
he hauls heavier than i do!!!
(we both have 8k lb trucks...........empty.
.....I just swapped out my fan clutch, took me about 30 minutes for the whole shebang. I put some blue thread lock on it just to be safe. But right after I tightened the nut and before the thread lock had any effect, I started the engine and revved it all the way up and then shut it off. The fan stayed on the engine and stopped as it should have.
Maybe Dave S.'s guys didn't tighten it correctly?
Brain is taking a long time getting my new one sent.i guess this time of year,like a lot of folks,he's pretty busy.
this time i ordered the WP85 (no i wont be using it for a water pump,it's just like the other but includes the dual wiring harness is all.so in my case,it will simply be two e-fan wires,and i can ditch my 3-way butt connector i have in there now) variable rate controller,L-101 indicator light,and the TADJ22 remote temperature adjustment:
Fan Control
this way,these things won't just spin on high when they come on.it's just too much all at once.i don't like seeing my engine temps swing so drastic.i figure it's no good for head gaskets.
when them dual windstar fans kick on high........they mean business.
i know many are still skeptical of e-fans,but it's true.they can over cool my engine inside 1 minute from 240 degree's,they'll start to make my t-stat close if i don't kick 'em back off.seriously.
so right now,while waiting for the controller,i simply pop the hood before i get into town and wire them on direct,or whenever i want the A/C.
relay's kept burning out,because i never took time to rig up one for each fan haha.
since i know when a fan is required and have a temp gauge,this is working out ok.
sometimes this means i need to pull over right away when i see 235/temp gauge flashing to turn my fans on though.
i wouldn't let anyone else drive my truck right now.
it will be nice when its all automated again.i hope he sends the thing out soon.
you'd be surprised how rare the fans even need to come on with this large cooling system.
traffic,large hills,and A/C pretty much only.
if so,then you want to grab two separate fans from your local salvage yard/ebay out of ford cars with the 3.0/3.8l engines.
known to last for many,many miles,and known to keep the idi cool.
Mel runs two of these on his Moose truck without any issues.
also don't forget,you will NEED to convert your alt to newer 3g before trying this(since these didn't come until mid year of '92.)if you don't,you will fail.
this is a very cheap and good to do mod anyway.it's extremely easy as well.search around this section,and you'll see guys show how to do it,and many claim it only set them back 15-20 bucks by using salvage yard alts.
a real aftermarket temp gauge should be used too.
this is all in the link below though.
https://www.ford-trucks.com/forums/9...onversion.html
Electric fans will work for some and fail miserably, on my big trucks the fans pull 40 horsepower when engaged, I would have electric fans if they would work.
