302 camshaft
Old Jul 17, 2011 | 04:26 PM
Tushy's Avatar
Tushy
302 camshaft
hi Guys,
I'm looking for a street performance camshaft to my 302,which will pull my 56 f100,but not really sure which would be good,
found ,Edelbrock 7122 - Edelbrock Performer RPM Cam and Lifter Kits - Overview - SummitRacing.com
or if somebody could explain the numbers meanings,or what I have to look,would be helpful .cheers,Tushy
Old Jul 17, 2011 | 04:38 PM
55F250's Avatar
55F250
AirForceVet
Need more info on this 302, is it stock? Are you going to keep it stock? Are you going to use stock heads? What kind of exhaust are you running? All these things will make a difference on which cam you want to get.
Old Jul 17, 2011 | 04:43 PM
Tushy's Avatar
Tushy
it's out of Lincoln,about 81,I've got an edelbrock 2121 intake,ed,600 carb,heads will be just standard at the moment,cannot afford better,exhaust just a cherry or muffler and on side.thanks
Old Jul 17, 2011 | 09:35 PM
blueovalandy's Avatar
blueovalandy
I have run that cam in a 302 and in a 289 and both times I loved it. It has a lot of chop and a very aggressive sound as well as decent drive-ability. It will give you a strong mid range and pulls hard around 2000 rpm - 5500 rpm. Your exact combination will affect how well this camshaft will work in your engine. Compression, valve size, port flow, intake type, header type, exhaust design, and carburetor will all be things you need to match to help this cam achieve its potential. However, the most important factor in any camshaft selection in my experience is actually the transmission. If you are running an automatic, this camshaft will be too radical for a stock torque converter. You will need to select a stall converter that will match the engine's new power curve. On the other hand, if you are running a manual transmission, it will be easier to run this camshaft. I prefer manual trans in performance builds because they are much more forgiving to mismatches in combination. Give Summit or Edelbrock a call to help you out with your decision. They both have tech guys that can walk you through your exact build combination and help you select the right camshaft to meet your goals.
Hope this helps,
Andy
Old Jul 17, 2011 | 11:38 PM
52 Merc's Avatar
52 Merc
IMHO, that's way more cam than your engine can use effectively. I think you would be sadly disappointed with it.Your intake is really no better than the stock 289 4v, except in aluminum, and with stock exhaust and Lincoln smog heads, you'll always be messing with it trying to get it to run right.
A cam that would be better suited for your package is one from Ford. It's a hydraulic version Ford developed based on the characteristics of the 271 hp, hipo 289 solid lifter cam. It's known as the C9OZ-C and is (afaik) still available from Ford. An outlet that will ship to you across the pond, and that I believe keeps them in stock is Glaziers Mustang Barn. Mustang Parts, Shelby Parts, and Restoration Services
Old Jul 18, 2011 | 05:16 PM
Tushy's Avatar
Tushy
thanks guys,I will find out,will ring them.Tushy
Old Jul 18, 2011 | 06:01 PM
eman92082's Avatar
eman92082
Too much for your combo. Keep your duration around 270-280 max and your lift under .500 with your rocker arm ratio.
Tushy
Aug 29, 2012 04:55 PM
Tushy
Oct 21, 2011 12:32 PM
The Ledge93
Oct 16, 2011 07:04 PM
The Ledge93
Apr 10, 2011 05:36 PM
USArmyTaterness
Jan 5, 2011 01:59 AM
