Is it safe to shoot a topcoat reducer rated at 85 degrees when its only 80 deegres. Will it just take a little longer to flash? The weather has been stuck at 80 for days now.
Yes, that will be perfect. The temp ratings are an approximate, and are only a guide, not anything set in stone. It also depends on how big of an area you're spraying. If you're only doing a spot on one panel, you could get away with using 70 reducer when it's 80, and conversely if you're doing a complete paint job, you might want a slower reducer, or perhaps a blend of 85 and 95, so it's not too dry by time you get all the way around the car.
Talent? I asked for some of that at the paint store and they said come back in twenty years and then I could have some (maybe). LOL Thank you guys, I wouldnt even attemt this without your help and inspiration.
A slower reducer shouldn't be a problem, just like Wayne stated. Now using a lower reducer in warmer weather can be a problem. I know, when I painted my F-2 I had planned for over a week to paint it. Temps were around 75° for a couple of weeks. The day I had planned to paint the truck the temps climbed into the 90s. For some reason, I don't remember it's been 18 years, I could only paint it on that one day. Well, I figured, if I kept the paint wet it should work out. Man, was I wrong. The paint dried fast and I ended up with paint the texture of 180 grit sand paper. I had to sand the entire cab down and start over, what a pain, not to mention the cost of more paint and reducer.
