wet is 14k, advertised hitch weight is 1900#, i go to colorado every year with my 9500 wet weight 5er and have no prob on any pass. love the tranny braking on my auto.
ford advertises 14500, i would be more like 12000 to 12500 max actual weight. looking for experience with that weight with a v10, it will prob do it but i dont want to kill it. i get 7 to 8 mpg currently w/ my 9500# 5th wheel dont know how much more itll drop w/2000# of trailer
Assuming you have a 4x4 crew cab truck with an automatic, the factory says you are good for 12,500 pounds conventional towing and 14,100 pounds 5th wheel towing. A lot of us here tow up to the factory limit without issues. Some tow over the limit without issues.
If your truck configuration is different, use these guidelines.
I'll give the weights from the cat scale. This is with the trailer loaded for full time living for the summer.(I'm sure there's one more thing to put in the trailer.)
Now I have 4.30 gears and not towing the mountains out west. I've pulled from northern part of NH to the southern part of Vt and climbed these hills with no problem.
RVPULLER on this site is using a 2000 V10 and pulling a Hitchhiker all over the states and seems to be doing it just fine.
The key to remember is your not going to win any races pulling at high altitude.
You have a 2wd, 4.30s are a cheap swap and will boost the RPMs at highway cruising speed. Maybe even 4.56s if you're worried about the big hills on I70. Will cost a lot less than changing out the truck to one with a diesel.
thanks scraprat. so you only weigh about 1100# more loaded than the advertised dry weight? and 240# more on adv. hitch weight if i read it correct
Correct, and that's with the fresh water tank about a quarter full. I kept looking for a trailer to fit my needs and still keep the weight down, and there is still some room to add some weight without being at max weight. Good luck and happy camping.
