Sponsored by: Real Truck
window electrical issue.
Old Jul 16, 2011 | 12:13 PM
bgalaxy67's Avatar
bgalaxy67
I have had this window issue for a few months now. It only happens in the mornings, so I am thinking it has something to do with temperature. Really wasn't an issue until this morning when the wife called while 500 miles away that one of the windows won't go back up
So the issue is, the passenger rear window will go down, but not up. After about an hour or so, it will start working normally again. Again, only seams to be a morning issue. This morning, the same issue also affected the sunroof. It was opened and when she went to close it, it wasn't working. Neither were any of the windows.
So I have her pull the fuse and all is good. When she put the fuse back in, the sunroof closed about 4" and then stopped again. I had her wiggle the fuse box while pushing on the buttons and there was no change. I had thought it was a connectivity issue at the fuse box, but it doesn't seam to be the case.
After awhile, the sunroof did start working again and all the windows are working as normal.
So my question for you all is, where do I look from here? It has to be a some sore of plug issue or even a grounding issue. Something where humidity is affecting contact but i'm not sure where in the harness to look for an issue.
Old Jul 16, 2011 | 02:36 PM
brd7666's Avatar
brd7666
You might want to provide some more information, like year, model, etc.
Old Jul 17, 2011 | 01:39 AM
bgalaxy67's Avatar
bgalaxy67
Ahhh crap. Everyone is supposed to know what I'm driving already
Truck is an 03 with the 6.0 crew cab lariat
poppop50
Jan 7, 2021 09:14 PM
Hemi Hunter
1997 - 2003 F150
Dec 17, 2013 03:28 PM
1bluexpy
15
Oct 7, 2004 12:56 PM
andersonl_us
Oct 2, 2004 03:06 PM
