Another OD light issue
Old Jul 14, 2011 | 09:27 PM
KYFarmBoy's Avatar
KYFarmBoy
I have a 2000 F-350 dually. I am having an intermittent problem with the the OD light. The symptoms are after coming to a complete stop the OD light starts flashing and when trying to move forward it feels as if the brakes are dragging and sometimes stalls out the engine. The codes read with a Superchip 1705 are p1670,p0720, and P0503. When I shift into park, the engine rpms jump from idle to about 1500-1600. I have replaced both the differential VSS and the transmission OSS but still have the same problem.
Any suggestions, would be greatly appreciated.
Old Jul 15, 2011 | 05:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The P0720 code doesn't mean replace the OSS. It means the computer can't read a signal from the OSS. Most of the time that means a broken wire between the OSS and the PCM.
Old Jul 16, 2011 | 05:25 AM
KYFarmBoy's Avatar
KYFarmBoy
Mark, thanks for the reply. Do you know if the wiring associated with this sensor is the same one that develops a short in the steering column?. It appears that if I don't use the turn signals the frequency of the problem decreases.
Old Jul 16, 2011 | 08:06 AM
Mark Kovalsky
I know that the OSS wiring is not the same as the wiring in the steering column. Both go to the PCM, but they are separate.
Old Jan 20, 2016 | 06:41 PM
Anthony McBride's Avatar
Anthony McBride
having the exact same problem, help
what was the fix?
branrobi
Jan 13, 2019 12:44 PM
Kifferman
New Member Introductions
Aug 28, 2018 01:21 PM
turbotech
Jul 19, 2017 04:04 PM
Phillipe
Sep 28, 2016 08:56 PM
ephexpi
Aug 17, 2016 12:10 AM
