Door lock key fob?
Old Jul 14, 2011 | 01:39 PM
Crewcab Turbo's Avatar
Crewcab Turbo
Door lock key fob?
I bought my truck and I wasn't given a fob for my door locks. Does anyone know if all f250 lariat crewcabs came with key fobs to unlock the doors? And how would I determine if my truck has the ability to have them? I would like to get one for my truck if possible. Thanks!
Old Jul 14, 2011 | 01:42 PM
ToMang07's Avatar
ToMang07
If you have automatic locks, you should be able to program a fob. I picked on up on ebay for $20 and programmed it using the directions in the owner's manual.
Old Jul 14, 2011 | 01:46 PM
Crewcab Turbo
I have an extra fob from my 97 expedition do u think that will work? Next I need to find the directions and try it I guess. Thanks
Old Jul 14, 2011 | 03:07 PM
ToMang07's Avatar
ToMang07
IDK if the older one will work. Do you have a manual? The remote programming instructions are in the manual. If not, here's a link where you can download a digital copy for free, as well as supplements and such: Official Ford, Lincoln & Mercury Owner Site | Personalized Owner Information
Old Jul 14, 2011 | 04:16 PM
hammer65's Avatar
hammer65
My 2003 EC had electric door locks, but did not have remote entry. Had to install after market. You can get a Build sheet from Ford and it will tell you if you have them.
Parts Guy ED might do it for you if he has time. (Build Sheet) All dealers should be able to do it, but I guess most of them are not as good as ED,
Old Jul 14, 2011 | 04:24 PM
Crewcab Turbo
Looked it up in the manual as instructed and it says to turn key forward 5 x and leave on and locks will lock to show it's in the program mode, then press a button on the remote. I assume it would not lock the locks if it doesn't have the option, I assume?
Old Jul 14, 2011 | 05:22 PM
ToMang07's Avatar
ToMang07
Did you start w/ the doors unlocked? I would think a Lariat has keyless entry... my XLT does.
How to reprogram your remote entry transmitters
You must have all remote entry transmitters (maximum of four)
available before beginning this procedure.
To reprogram the remote entry
transmitters:
1. Ensure the vehicle is
electronically unlocked.
2. Put the key in the ignition.
3. Turn the key from the 2 (LOCK)
position to 3 (OFF).
4. Cycle, eight times, rapidly (within
10 seconds) between the 3 (OFF)
position and 4 (ON). Note: The
eighth turn must end in the 4 (ON) position.
5. The doors will lock, then unlock, to confirm that the programming
mode has been activated.
6. Within 20 seconds press any button on the remote entry transmitter.
Note: If more than 20 seconds have passed you will need to start the
procedure over again.
7. The doors will lock, then unlock, to confirm that this remote entry
transmitter has been programmed.
8. Repeat Step 6 to program each additional remote entry transmitter.
9. Turn the ignition to the 3 (OFF) position after you have finished
programming all of the remote entry transmitters.
10. The doors will lock, then unlock, to confirm that the programming
mode has been exited.
Old Jul 14, 2011 | 05:32 PM
hotroddsl's Avatar
hotroddsl
If not equipped the doors will not lock
Old Jul 14, 2011 | 06:27 PM
Crewcab Turbo
Just tried it and the doors locked and unlocked at the fifth key cycle. My fob from my 97 did not work. Seems like the truck has keyless entry.
Old Jul 14, 2011 | 06:40 PM
pjnadon's Avatar
pjnadon
The fob from my old 97 F250 and one from a 2004 F150 worked on my 2006 F350 and also my 2002
If it locked when u cycled the key the you have power locks make sure the battery in the fob is good also if it doesnt take much for the fob to not work if the battery is weak
Old Jul 14, 2011 | 06:50 PM
BigAlsPSD's Avatar
BigAlsPSD
I bought mine here, Ford Keyless Entry Remote Transmitter Refurbished | Keyless Remote & Replacement Keyless Entry Remotes at keyless-remotes.com, I bought the refurbished 3 years ago and have had no issues, quick shipping, I think it was a day or 2
palindromelol
Jun 30, 2016 06:29 AM
User 72324
6.7L Power Stroke Diesel
16
Nov 23, 2010 03:51 PM
mkac100
Oct 9, 2009 07:35 PM
ExpySport
Oct 22, 2008 07:40 PM
Beamer 2
Mar 15, 2008 10:12 AM
