Auto Re-lock?
Does the 2011 Super Duty do something like this? I don't think it does but thought I'd ask. The reason I ask is that on one occasion DW or I must have hit the unlock button by mistake (key fob in her purse, or me bumping my keys, etc.) and the truck was unlocked all night.
If it doesn't automatically re-lock, is there any way to disable the key fob if necessary, other than removing batteries?
The locking part drives me crazy, so I changed mine to not auto lock, so that way if someone needs to jump in, I don't have to unlock the doors, but it does auto unlock when put into park (just in case)
Gordon
Gordon
Yeah, I have it set to auto lock and unlock. But it is not unlocking the rear doors...only the front doors. I may have to just set it to not auto lock. Thanks
its turn off the key AND OPEN the drivers door. (not going into park)
Autounlock feature (if equipped)
The autounlock feature will unlock all the doors when:
• the ignition is in the on position, all the doors are closed, and the
vehicle has been in motion at a speed greater than 12 mph (20 km/h);
• the vehicle has then come to a stop and the ignition is turned to the
off ) or accessory position; and
• the driver door is opened within 10 minutes of the ignition being
transitioned to the off or accessory position.
Note: The doors will not autounlock if the vehicle has been
electronically locked before the driver door is opened.
if you use the remote, you can change from front/them back to all unlock
Two step door unlocking
1. Press and release to unlock the driver’s door. Note: The parking
lamps and interior lamps will illuminate (refer to the Illuminated entry
feature later in this section) if the control on the overhead lamp is not
set to the off position.
2. Press and release again within three seconds to unlock the
passenger doors.
The battery saver feature will turn off the lamps 10 minutes after the
ignition is turned to the off position.
One step door unlocking
If the one step door unlocking feature is activated, press and release
once to unlock all of the doors. Note: The parking lamps and interior
lamps will illuminate (refer to the Illuminated entry feature later in this
section) if the
