fuel leak at inspection cover?
Old 07-14-2011, 11:34 AM
97XLT4X4's Avatar
97XLT4X4
97XLT4X4 is offline
my poor truck is leaking fuel (9 mpg)
i crawled under and its coming from between the starter and the engine (inspection cover?)
there looks to be a gasket on the side that is missing on the bottom and lets the fuel leak out.... is a gasket required for here?
Old 07-14-2011, 11:43 AM
arkredneck's Avatar
arkredneck
arkredneck is offline
From what I understand most fuel leaks come from the valley check the hoses on the fuel lift pump and the fuel filter housing check the big nut on the back of the lift pump there are a few sensor that are on the fuel filter housing that can leak. Clean the valley up really good and get a brite flash light and start the truck and see If you can pin point the leak there is also a weep hole on the bottom of the lift pump that can leak when the pump wears out
Old 07-14-2011, 11:58 AM
bad12jr's Avatar
bad12jr
bad12jr is offline
The problem is in the valley. It has a drain port in the back of the valley. The pumps have weep holes and will leaking when they start going out.
Old 07-14-2011, 01:04 PM
97XLT4X4's Avatar
97XLT4X4
97XLT4X4 is offline
i drained the fuel bowl on monday and when i closed the drain, its been leaking ever since, the first day the worse, it was fine yesterday and today its back again, i cleaned under the truck and it isnt coming from up high, its coming from right at that point i mentioned
Old 07-14-2011, 01:20 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
As mentioned above the leak must come from the valley, maybe the oring of the cap of the cannister is wrong, pinched or simply loose. There are other common places where the leak can come, the first is the fuel pump, other the fuel restriction sensor in the cannister, other the fuel lines and also the cannister itself by tiny pineholes in the bottom.
Old 07-14-2011, 03:22 PM
97XLT4X4's Avatar
97XLT4X4
97XLT4X4 is offline
this sucks, just because i drained the fuel bowl now i need to fix something
Old 07-14-2011, 08:39 PM
bad12jr's Avatar
bad12jr
bad12jr is offline
Honestly draining it could have got the gunk out and gave the system more pressure. This would put more strain on an already weak part and made it go the rest of the way.
Old 07-15-2011, 08:05 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
I forgot but also the drain valve can leak by itself for bad o-rings.
Old 07-15-2011, 09:11 AM
97XLT4X4's Avatar
97XLT4X4
97XLT4X4 is offline
great i'll look into it sometime soon i guess....any threads on common fuel leaks?
Old 07-15-2011, 09:17 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Ask and 'ye shall recieve:
From the "Tech Mod/Info Links" thread stickied at the to of the main page.
Fixing common fuel system leak points:
https://www.ford-trucks.com/forums/80...-write-up.html
https://www.ford-trucks.com/forums/98...eak-fixes.html
Good luck!
Old 08-04-2011, 12:57 PM
97XLT4X4's Avatar
97XLT4X4
97XLT4X4 is offline
well i poped the hood today while it was spewing out the bottom and found something!
the fuel filter housing was leaking out the top,took out the filter, made sure the o ring was on right. tightened it back up and wala,no more leak today!
Old 08-04-2011, 01:14 PM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Great! I loveee easy fixes!
Edit: Oh and I dont know if you do what I do, but that stupid "direct injected turbo diesel" plastic cover that sits in the way. You can take that off and leave it off... it helps when trying to eyeball problems
Old 08-04-2011, 03:34 PM
97XLT4X4's Avatar
97XLT4X4
97XLT4X4 is offline
every car i own has had the engine cover removed during warm months, it traps heat!
Old 08-05-2011, 08:29 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
And the winner is ...........
Glad to hear that you fixed up and no more leaks.
PS: BTW there is no any gasket on the side that is missing on the bottom.
sschevel
16
05-16-2016 09:52 PM
Carloespo
10-31-2015 09:27 PM
dentsides
04-22-2015 08:29 AM
DanMan7
06-23-2007 11:47 PM
ceetwarrior
03-21-2005 11:45 AM
Quick Reply: fuel leak at inspection cover?
