fuel leak at inspection cover?
my poor truck is leaking fuel (9 mpg)
i crawled under and its coming from between the starter and the engine (inspection cover?)
there looks to be a gasket on the side that is missing on the bottom and lets the fuel leak out.... is a gasket required for here?
From what I understand most fuel leaks come from the valley check the hoses on the fuel lift pump and the fuel filter housing check the big nut on the back of the lift pump there are a few sensor that are on the fuel filter housing that can leak. Clean the valley up really good and get a brite flash light and start the truck and see If you can pin point the leak there is also a weep hole on the bottom of the lift pump that can leak when the pump wears out
i drained the fuel bowl on monday and when i closed the drain, its been leaking ever since, the first day the worse, it was fine yesterday and today its back again, i cleaned under the truck and it isnt coming from up high, its coming from right at that point i mentioned
Ask and 'ye shall recieve:
From the "Tech Mod/Info Links" thread stickied at the to of the main page.
Fixing common fuel system leak points:
https://www.ford-trucks.com/forums/80...-write-up.html
https://www.ford-trucks.com/forums/98...eak-fixes.html
Good luck!
Good luck!
Edit: Oh and I dont know if you do what I do, but that stupid "direct injected turbo diesel" plastic cover that sits in the way. You can take that off and leave it off... it helps when trying to eyeball problems
As mentioned above the leak must come from the valley, maybe the oring of the cap of the cannister is wrong, pinched or simply loose. There are other common places where the leak can come, the first is the fuel pump, other the fuel restriction sensor in the cannister, other the fuel lines and also the cannister itself by tiny pineholes in the bottom.
And the winner is ...........
Glad to hear that you fixed up and no more leaks.
PS: BTW there is no any gasket on the side that is missing on the bottom.
Carloespo
10-31-2015 09:27 PM
dentsides
04-22-2015 08:29 AM
DanMan7
06-23-2007 11:47 PM
ceetwarrior
03-21-2005 11:45 AM
