how much rust bullet should I order?
Old Jul 13, 2011 | 11:39 PM
danger-ranger93's Avatar
danger-ranger93
Anyone know, or recall how much it should take to coat my f250 4x4 frame? Its standard cab LWB.
I really would like to order some before friday.
Thanks!
Old Jul 13, 2011 | 11:48 PM
MikeS29's Avatar
MikeS29
I bought one gallon (4 quart cans) and still have one yet to crack open, but I will be opening it to touch up a few spots on my frame that I wasn't as good at painting as I had thought I was. Mind you, I used a brush, so was a little heavy-handed in some places. With the right spray equipment, I am guessing you could cover it easily with 3 quarts.
Old Jul 14, 2011 | 12:09 AM
danger-ranger93
Sweet, thanks, I think I'll just get the gallon. Then I'll have some for every nook and cranny.
Old Jul 14, 2011 | 01:10 AM
MikeS29's Avatar
MikeS29
Pics before and after, too!
Old Jul 14, 2011 | 09:20 AM
PA74F250's Avatar
PA74F250
whoooa a gallon for the frame? Is the rust bullet as expensive as the POR-15? I bought a quart of that and I maybe used a quarter of it to do a D60 front. I used it liberally too also brushed it. That stuff goes a long way. I think there is another member on here that did his whole frame with a qt. of POR-15. It's up to you and it's your money but I think a gallon is a little much for the frame.
Old Jul 14, 2011 | 10:47 AM
danger-ranger93
Well, the gallon won't be used JUST on the frame, I'm talking about, cab floors, bed floor, back side of fenders, leaf springs, and I plan on doing multiple coats in all of those places.
Old Jul 14, 2011 | 11:52 AM
buckshot1822's Avatar
buckshot1822
I used POR15 on my frame, radius arms, both axles, differentials, basically everything underneath, and it took all of a quart......
Old Jul 14, 2011 | 12:13 PM
danger-ranger93
Maybe Por-15 is the way to go.... Really down here I could get away without any coating and it would be fine, but I want it to have that finished look top and bottom.
Old Jul 14, 2011 | 10:38 PM
danger-ranger93
So I ended up ordering a quart of rust bullet. We'll see. It only takes a day to ship ground from summit to my house.
Old Jul 15, 2011 | 12:03 AM
MikeS29's Avatar
MikeS29
Only thing to be careful of is: 2 coats (or more) is mandatory, so make sure you get it sealed up without air or it will harden. When I did mine, I looked at each quart as a separate coat. Partial quarts need special care to keep them viable.
Old Jul 15, 2011 | 01:52 AM
danger-ranger93
Maybe I can make this quart strech enough, I'm going to spray it, just because I got the equipment and it seems like that will let it last longer.
Old Jul 15, 2011 | 09:15 AM
Steel Toy's Avatar
Steel Toy
Click on my build thread link - I had made some comments on my use of RB that may be of some info
joelariat
Oct 2, 2016 07:13 PM
wa-sleeper
1997 - 2003 F150
Oct 24, 2015 12:09 PM
tperk100
Feb 7, 2011 06:15 PM
ColdH2O
6.7L Power Stroke Diesel
923
Dec 20, 2010 02:29 AM
