Highboy power steering conversion question
Old Jul 14, 2011 | 10:50 PM
cabloom300's Avatar
cabloom300
I have a question as to which ps lines do i use off the old hydro assist ram. Im thinking that i use the 2 lines that go to the pump and the other to that go to the ram mounted on the axel are eliminated? Also, i attached a pic of the 78/79 box, can someone tell which lines go to what? Any help is appreciated. Thanks
Old Jul 15, 2011 | 09:13 AM
daningraham's Avatar
daningraham
I did not use any of the lines off the old system when I installed my 78' box into my 74'. Had to have a new one made for the pressure side and used fuel tubing on the return. If I recall correctly, the smaller line is the pressure one and the larger one is the return (seemed backwards to me, but that is how it worked).
Old Jul 15, 2011 | 09:46 AM
co425's Avatar
co425
The fitting on the left is high pressure and the right is return. Go to a hydraulic shop they should be able to make you a fitted hose for about $50.00.
Highboy74
Oct 5, 2016 09:58 PM
paredneck33
Ford vs The Competition
Jun 21, 2016 01:21 AM
troverman
May 30, 2016 11:25 AM
RM2012F350
6.7L Power Stroke Diesel
112
Sep 3, 2014 07:05 PM
Robertcoupe
18
Jan 26, 2011 06:08 PM
