Ferret Timing Device
Old Jul 13, 2011 | 06:19 PM
540milotalon's Avatar
540milotalon
Just got my new Ferret pulse timing tool. I have a antique timing light. Will I be able to use it? Will I need to buy new light?
Old Jul 13, 2011 | 06:30 PM
swooshcmk's Avatar
swooshcmk
Can you dial in the degrees on the timing light or will it only flash when you pull the trigger?
You could get by with one that just flashes, but you'd have to mark your crank pulley for the 8-9*BTDC to line the strobe up to.
A more modern light that lets you dial the degrees in AND gives you RPM readout is the cat's meow
Old Jul 13, 2011 | 06:52 PM
540milotalon
Nah, it's a flash only. Could the timing mark be marked using a protractor?
Old Jul 13, 2011 | 08:57 PM
Otahyoni's Avatar
Otahyoni
How does a timing light with adjustable advance predict 8° BTDC?
I suppose if you knew the diameter of the balancer you could use some math to turn 8° into a measurement....
Old Jul 13, 2011 | 10:18 PM
540milotalon
Well, that's what I was thinking. I've yet to measure anything; but thought, say the Harmonic bal. was 8" multiplied by 3.1416 divided by 360 times the 8*=.5585 measured on the radius. One degree off would be 1/16 of an inch+/-. I used to be that good. As a matter of fact, the older I get the better I was in a lot of things.
Old Jul 14, 2011 | 04:23 PM
38Chevy454's Avatar
38Chevy454
Just as you thought, the mark is about 9/16 inch from the TDC line. I made a new line for the timing. You need to use an inductive timing light, not an old in-line style. I had trouble to get the timing light to pick up the signal, had to fiddle with it some and finally got it to work. A dial back timing light could be used and not need to mark the line on balancer 9/16 inch away.
Old Jul 14, 2011 | 07:39 PM
540milotalon
Thanks 38, I was hoping my meds weren't off a little. I might buy a new light soon anyway. Like Swoosh was saying, being able to check the rpm would be nice.
Old Jul 16, 2011 | 04:20 PM
Marianna2003's Avatar
Marianna2003
It reduces everything to a time calulation. If you know how fast it is running, then it would be easy to divide it into 360 segments to deteremine when to flash.
jmuenchow
15
May 1, 2021 02:00 PM
R1racer
18
Mar 31, 2017 10:39 PM
hairyboxnoogle
Oct 23, 2016 10:10 PM
fhafer
19
Dec 3, 2015 10:58 PM
therifleman556
May 2, 2012 12:17 AM
