Custom Center Console
Old Aug 24, 2011 | 09:38 PM
  #46
jgavac's Avatar
jgavac
Originally Posted by devino246
2 questions:
1) How the he// am I gonna cut out a square opening measuring approx. 1/2x1 in 16ga aluminum? Push come to shove, I know a guy who has one of those hydraulic presses that can punch any size hole, but it would be a month or so before I could get it to him and get it back.
Other option would be a jigsaw with a fine tooth metal cutting blade. It won't give you burr free edges, so you would want to rasp/sand it when you are done. You would need to do a plunge-in, but those are not terribly hard to do (try it a few times in scrap metal first).
Center console looks good man. I thought about doing one when I first got my truck to house a sub, but that idea never got off the ground.
Old Aug 24, 2011 | 11:30 PM
  #47
four-sixty-power's Avatar
four-sixty-power
Do you mean 1/2 inch by 1 inch? Drill a hole, get a file with a corner on it, start filing to desired square size.
I did 12 holes for a canopy door through 1/4 inch aluminum, didn't take long, the hardest part was they were small holes for small carriage bolts and the file just barely fit.
Old Aug 25, 2011 | 01:50 PM
  #48
devino246's Avatar
devino246
Thanks for the ideas guys. Ill try one of them out this weekend.
On a somewhat unrelated note: me and my friend are going to a cruise-in on friday over in Oakboro. What kind/quality of cars are usually in those things? Would I look like an idiot if I brought my truck? Im mean, its not exactly perfect, but it is in good shape for a 79. Pics of it in my garage...
Old Aug 25, 2011 | 02:32 PM
  #49
whistle1516's Avatar
whistle1516
How about a console with a flip up top, sealed inside with a drainage tube running out of the floor? You could put a sixpack of hmmm.......coke in there.
Old Aug 25, 2011 | 03:00 PM
  #50
devino246's Avatar
devino246
Old Aug 25, 2011 | 03:30 PM
  #51
whistle1516
You could kick it up a notch by taking your hose running to your windshield fluid squirters and running it throught the firewall. Then running it into your console. You need to drill a hole on the side then stick a 90 on the end. Wash out your washer fluid tank and presto! Any time you want some poison for your mixed drink push your fluid button.
Old Aug 25, 2011 | 04:05 PM
  #52
devino246's Avatar
devino246
hahaha. My auto tech teacher told up a few stories about how he and his friends turned the windshield washer nozels pointing outwards, peed in the reservoir, and then drove through downtown Myrtle Beach showering people with ****! He also gave us the idea of running lines to the back bumper, and filling the reservoir with brake fluid in case someone tailgates you
Old Aug 25, 2011 | 09:25 PM
  #53
kevin316's Avatar
kevin316
devino, it's a bit late but I hope you went to the cruise night. If it's anything like where I live there will be everything from trailer queens to works in progress to off the lot family cars (nice ones though).
I love just going and getting some inspiration from people. Find out who did their paint, what do the run for power...just shoot the ****.
Old Aug 25, 2011 | 09:48 PM
  #54
Undermydent's Avatar
Undermydent
Very nice, keep it up and keep us posted!
Old Aug 26, 2011 | 02:07 PM
  #55
devino246's Avatar
devino246
Its tonight, but my friend who was gonna come cant and I dont feel like going out there by myself. We'll go next month and he'll bring his '84 C10 stepside(I almost killed him when he bought a chevy)
Thanks, will do.
Old Aug 26, 2011 | 10:15 PM
  #56
devino246's Avatar
devino246
This stuff must be some type of alloy, I ruined 2 jig saw blades but got it done. Afterwards, I sanded the piece in several directions to smooth the appearance. Later on, Ill drill holes for the switches.
Im goin to Radio Shack tomorrow to pickup some bulbs to backlight the labels. Ive got some copper clad circuit board and some etching solution so Ill have it all nice and neat. Im planning on running the backlights off the dash light circuit. Any idea how many bulbs I can add before I start risking blown fuses?
Old Aug 27, 2011 | 11:53 AM
  #57
devino246's Avatar
devino246
Hmm, wonder if I could get a few bulb sockets off a junkyard gauge cluster. I guess I could also order some from DC since I still need to order some other little things. Ive got a fishtape sitting in my B pillar at the moment, Im planning on running a 16ga wire for the backlights and a 14ga from the fuse block to the switch for the front & back lights. Then 16ga from the switch out to the lights.
Old Aug 27, 2011 | 05:50 PM
  #58
devino246's Avatar
devino246
Got the wires run. I ended up running the wires along the floor and then up the B pillar.
Old Aug 29, 2011 | 07:32 PM
  #59
devino246's Avatar
devino246
Well that turned out well! There are two bulbs that backlight the labels when the lights are turned on, they dim with the dash lights. When you flip a switch, it lights up a red LED behind that label. Used a 680ohm resistor and a wide angle red LED, btw.
Old Sep 13, 2011 | 09:34 PM
  #60
devino246's Avatar
devino246
Final product:
