flywheel info please
Old Mar 29, 2003 | 10:29 PM
hawk250's Avatar
hawk250
having starter problems/flywheel problems. <a href="http://www.motorhaven.com/">400m </a>starter and bellhousing, with a '69 <a href="http://www.motorhaven.com/">429 </a>, and a <a href="http://www.motorhaven.com/">390 </a>flywheel. found out why teeth are getting buggered. <a href="http://www.motorhaven.com/">390 </a>fly has 184 teeth while 400 fly has 164 teeth and also different diameters. What i need to know is what way is the best way to go. Also can a 300 fly fit. Engine is internal balance.
Old Apr 2, 2003 | 07:42 PM
mr clutch's Avatar
mr clutch
Hawk
A simple solution most do not think about. Take your flywheel to a machine shop and have them flip the ring gear and surface the flywheel. The ring gear will get damaged on the starter drive side but usually the engine side is like brand new. I hope this helps.
oldford2
Apr 3, 2003 10:23 AM
orangeford
Apr 1, 2003 10:54 AM
junjer
1966 - 1977 Early Broncos
Mar 30, 2003 11:17 PM
79f250&70Mustang
Mar 30, 2003 06:05 AM
Seabeetough
Mar 26, 2003 10:10 PM
