Help with P0443 and P0713 codes
Old Jul 12, 2011 | 09:13 PM
jvh16's Avatar
jvh16
Question Help with P0443 and P0713 codes
I am still having troubles with the following codes P0443 and P0713. I have replaced the purge valve solenoid and the solenoid in the transmission and I am still getting the same codes. There is power going to the purge valve. The overdrive off light will flash even when the truck is cold. It stops flashing when it is driven about 3 miles (it is full of fluid). What am I missing? The P0443 light was the first to come on a few weeks ago, but sometimes, it would just go out by itself. Now the check engine light stays on. Is this caused by the PCM going bad?
Old Jan 26, 2024 | 03:13 PM
hotrodjohn71's Avatar
hotrodjohn71
Did you solve the problem?
XionTheBrony
33
Feb 28, 2013 10:59 AM
kellymastin
Feb 17, 2012 02:38 PM
drembedded
22
Aug 17, 2011 09:43 AM
woodduck17
Jul 29, 2009 10:48 AM
WildTurkeycj8
Modular V8 (4.6L, 5.4L)
Apr 18, 2004 04:26 AM
