7.3 compression testing
Old Jul 12, 2011 | 06:10 PM
dieselaholic's Avatar
dieselaholic
does anyone know what kind of #'s a compression test should be at for a 7.3L idi?
Thanks
Old Jul 13, 2011 | 12:52 AM
94 smokin stroker's Avatar
94 smokin stroker
To perform a compression test on this engine, you need to have a diesel compression gauge and a glow plug adapter. Remove all the glow plugs to check any cylinder. Crank the engine at least five revolutions and the same number of revolutions for each cylinder. It would probably be a good idea to have a battery charger hooked up during the test. Ford lists no compression specs for these engine, only stating the lowest cylinder should be no more than 25% lower than the highest cylinder, with a low to high comparison chart showing a range of 195 to 440 PSI. In reality the compression should be at least 350 psi in all cylinders found this on google posted by dieselmann
therigwelder
Dec 30, 2016 08:56 AM
rr1956
Jan 27, 2016 02:28 PM
truck7575
36
Nov 1, 2015 02:40 PM
copracr
28
May 20, 2012 03:46 PM
mikerc
Mar 23, 2004 09:29 AM
