85 bronco t-case
Old Jul 12, 2011 | 05:14 PM
fordcummins79's Avatar
fordcummins79
85 bronco t-case
just wondering if a t-case out of a 85 bronco will bolt up to a 92-96 small block 5 speed trans. ??
Old Jul 12, 2011 | 05:46 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
If I remember correctly the output shafts are different
Old Jul 12, 2011 | 05:49 PM
fordcummins79
Damn not what I wanted to here
Old Jul 12, 2011 | 09:29 PM
Franklin2's Avatar
Franklin2
Yes it will, all Ford 4x4 trannies will bolt up to any transfer case that was in a Ford. You have to watch out for shifter variations and transfer case output shaft variations such as fixed yoke and slip yoke. Ford used several different types of transfer cases through the years, so there are minor length variations also. But they all will slip on and bolt up to the Ford trannies.
Old Jul 12, 2011 | 09:40 PM
fordcummins79
Thats what I thought so ill be able to take a tranny from a 93 f150 an put it in my bronco that had a c6 with no problem other then length?
Old Jul 13, 2011 | 12:28 AM
Franklin2's Avatar
Franklin2
You were asking about transfer cases. Trannies depend on what engine the donor truck had, and what engine you are using in your truck.
Old Jul 13, 2011 | 12:48 AM
dohc_chump's Avatar
dohc_chump
The thing you have to remember is, the output shaft on the Bronco is shorter to accommodate the double carden joint. As for swapping in a 5 speed, there's more to it than just bolting it up. What trans are you thinking of swapping in, the ZF or M5OD?
Old Jul 13, 2011 | 05:23 AM
fordcummins79
I just wanted to make sure I could use my old transfer case. I plan on putting a M5OD in it.
