Could this be my timing
Old Jul 11, 2011 | 10:14 PM
93idi7.3's Avatar
93idi7.3
Hey guys as u no i was having probs with my return line kit, well i bought 8 reman injectors n the return line kit for 137 dollars shiped, i but it all in n it worked. Only one problem, now it takes like 20 seconds of cranking for it to start, if it starts, most off the time i got to use starting fluid. Also my truck shakes at a idle, but i drives just just fine, does any one no wats wrong
Old Jul 11, 2011 | 10:55 PM
84-6.9L's Avatar
84-6.9L
Your new injectors retarded your timing because they are holding until the speced pop pressure, try advancing it a dimes width on the marks and see how that treats you.
Old Jul 11, 2011 | 11:38 PM
93idi7.3's Avatar
93idi7.3
It that passenger ur driver side i turn it
Old Jul 12, 2011 | 09:55 AM
84-6.9L's Avatar
84-6.9L
tip the top of the pump to the pssenger side.
Old Jul 12, 2011 | 05:01 PM
eatont9999's Avatar
eatont9999
Sounds kind of like my issue when I installed my new IP and injectors. Mine started fine though. I have the old stuff back on it now. It was running rough and shaking like there was a dead injector or two. I'll try it again some other time.
Old Jul 12, 2011 | 08:17 PM
93idi7.3's Avatar
93idi7.3
Is there a thread that explains the process cuz I can't find it in my book
Old Jul 12, 2011 | 09:43 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
https://www.ford-trucks.com/forums/3...mp-timing.html
no meter;skip to here:
https://www.ford-trucks.com/forums/3...ml#post9927448
93idi7.3
23
May 17, 2016 05:01 PM
dcullen
Dec 10, 2013 05:30 PM
mechelement
19
Jan 19, 2010 03:04 PM
dyoungen
33
Jan 9, 2010 11:49 PM
jeffdoerr
17
Jan 21, 2006 12:07 PM
