Stud Girdles, when do you need them?
Old Jul 11, 2011 | 09:46 PM
Blue Rebel's Avatar
Blue Rebel
Hey guys, wondering when it is best to use stud girdles? Are they an all the time kind of thing, or only in high RPM applications, or high valve lift, or what? Thanks for clearing this up, looking to get one step closer in my engine build!
For reference, the engine in question is a 351W, wont go above 6k rpm
Trick flow 185cc heads
comp cams extreme 4x4 cam
Lift: .493''/.512''
Duration: 262°/270°
Thanks for any help!
Old Jul 11, 2011 | 11:05 PM
85e150's Avatar
85e150
I think you need them if you are going to run that motor at higher revs for extended times, or if you simply have an extra $300 to throw at it....
http://www.adperformance.com/index.php?main_page=product_info&cPath=264&product s_id=692
Old Jul 12, 2011 | 08:41 AM
mark a.'s Avatar
mark a.
Unless you are turning high rpm and using a roller cam with lots of spring psi you don't need them.
Old Jul 15, 2011 | 12:04 AM
my69's Avatar
my69
my69f100
You may be better off getting screw in studs put into your heads and roller rockers with posi locks.
muscletruck7379
Sep 15, 2011 01:12 PM
fordzilla01
Jul 10, 2011 06:48 PM
393STROKER
Aug 8, 2009 12:34 PM
jamies460
19
Jun 7, 2008 10:52 PM
wvmudder
Apr 1, 2005 12:45 AM
