Brake Line Failure
Old Jul 11, 2011 | 09:42 PM
BobbyB's Avatar
BobbyB
Brake Line Failure
I had a brake line fail last week while I was on vacation. We were traveling on the interstate and about four cars in front of me locked up their brakes. I got on my brakes hard and was going to stop, but the van in rear of me hit my rear bumper. As soon as they hit me, my pedal went almost to the floor. There was minimal damage to my truck and the van that hit me. I limped to the next exit about a mile away and pulled in a truck stop. The brake line that goes from the proportioning valve to the left front caliper hose failed. There is a short section of steel braided hose in the pipe just after it exits the proportioning valve. The steel braid had a tear and the hose ruptured. There was an Advance Auto parts nearby and I was able to replace the hose section with a steel line and a couple of compression unions.
I'm not sure if I want to (or need to) replace the repaired line with an OEM brake line. I don't see why the line needs a flexible hose. The proportioning valve and connection at the frame don't move. Also, it concerns me that the line ruptured in the first place, maybe it was already damaged?? There are two other flexible lines exiting the proportioning valve also. Has anybody seen any problems with these?
Old Jul 11, 2011 | 10:35 PM
BLADE35's Avatar
BLADE35
first Iv heard of a brake line failure sounds pretty dangerous
make shure you get the air out some of that abs stuff can be a PIA
some need a computer to open and close the valve while its being bleed not shure about our trucks procedure
JEDWIN
Feb 22, 2012 03:46 PM
yellow truck
Jul 6, 2009 04:46 PM
w.a.nelson
Oct 27, 2008 03:07 AM
davidsca
May 13, 2006 11:44 PM
mshumack
Sep 12, 2002 04:02 AM
