Will not idle
Old Jul 11, 2011 | 06:14 PM
rustyranger390's Avatar
rustyranger390
Will not idle
Where could trash be in the carb that a chem dip would maybe fix,
opposed to blowing carb out with blast air and cleaner would not fix? (like I did twice)
73 F100 360 2bbl
Old Jul 11, 2011 | 06:25 PM
co425's Avatar
co425
The bowls and jets.
Old Jul 11, 2011 | 06:54 PM
rustyranger390
OKAY well I'm gonna try it then. I'm at the end of my rope.
(It was a reman 15yrs ago btw.)
Old Jul 11, 2011 | 07:17 PM
rustyranger390
bump
Could trash in carb allow it to run really great one day and then like absolute crap the next?
Could this extreme happen due to carb trash?
Old Jul 11, 2011 | 07:22 PM
co425's Avatar
co425
Yes. You really need to buy a rebuild kit. Disassemble the carb completely and dip all the parts that didn't come new in the kit. Scrub out anything that didnt come off and dip again. Then spray it out with the garden hose let it all dry and re assemble.
Old Jul 11, 2011 | 07:34 PM
fmc400's Avatar
fmc400
MSEE
If all you have done is blow out the carburetor with carburetor cleaner spray, then the only way to ever make it run right again is to fully rebuild it and clean it with Chem Dip. If you've been spraying at a 15 year old carburetor, then I can gaurantee you've moved around enough varnish and junk that the only way to fix it now is to rebuild it the right way.
From reading your posts, it sounds like you've been told you need to rebuild it the right way, and you probably know you need to rebuild it the right way, but you're avoiding that at all costs. It's not going to happen.
Note that a carburetor rebuild does not gaurantee that a rough idle issue will be solved - that could be something else. That doesn't mean you don't need to rebuild the carburetor, because you do.
Old Jul 11, 2011 | 07:47 PM
rustyranger390
As always thanks FMC and co425
Brother helps me alot and he actually got a little pissed when I told him I took it off again.Yep gonna do it right. It's not just rough idle now...IT won't idle at all.Dies
Just saw something on youtube.
I swapped out the air horn for one at a junk yard because I beat holes in mine trying to unstick the float one morning late for work.I was unaware of the importance of that small tube thing on the air horn. The guy online said something about drilling it out but Im gonna check to see if my JY air horn is simply clogged. (something my brother did not blow out. After that it's chem dip time by gosh. Man I've tried everything else.
edit .hell my air horn did not have that small tube?
I thought it was a MC 2100?
59'er F100
Apr 10, 2009 11:36 AM
stevef100
24
Jan 19, 2009 08:23 AM
hotrodkid13
Dec 12, 2008 03:15 PM
Plain Old Dave
Tennessee Chapter
Dec 3, 2005 03:19 PM
natron83
Sep 3, 2003 02:18 AM
