Sponsored by: Auxito
gear box adjustment
Old Jul 11, 2011 | 05:52 PM
emtonelli's Avatar
emtonelli
gear box adjustment
My 02 f150 4x4 has 40,000 mls, put new tires and shocks on in dec. of 2010. Also had alignment done. Now I have alot of side to side wander. Been to 2 other shops front end is tight, tire shop replaced all 4 tires again with no help. Could it be the gear box at 40m?
Old Jul 11, 2011 | 06:27 PM
Bluegrass 7's Avatar
Bluegrass 7
Find out what the caster and camber readings are vs spec. Are they in spec.
It could be the tire make and version as well. If so replacing them with the same won't fix it.
Check for broken anti roll (sway bar) links.
Steering box to frame tightness.
Steering linkage.
Is there any play in the steering wheel?
Could be the power steering response.
Check these out yourself. You have to many shops involved as it is.
Lots of possibilities and even more than one.
Funny none is finding any issue!
Good luck.
Old Jul 11, 2011 | 10:31 PM
steve(ill)'s Avatar
steve(ill)
any good shop could tell you in 15 minutes what is loose. if not ball joint wear, then could be tie rod ends, steering arm anchor to the frame (idler arm bushing)... assuming the alignemnts is good. Jack up one tire 2 inches off the gound with a jack under hte a-frame. grab that tire and pull/ push it left to right as in turning. have your buddy lay under radiator and see what is moving and what is stationary.
arkredneck
Nov 22, 2014 08:28 AM
lmassmann
Apr 23, 2014 08:31 AM
ob_one
May 28, 2012 07:49 AM
snakedoc
All Things Towing
Jun 1, 2011 11:07 PM
weatherguard
Jul 15, 2004 05:35 AM
