Does your a/c suck?
Old Jul 11, 2011 | 11:08 AM
Hunt89's Avatar
Hunt89
Does your a/c suck?
My truck is in my sig. About 2 years ago my a/c compressor imploded and destroyed my entire a/c system. It was so bad that if I turned on the a/c it would instantly kill my truck. I got it all fix now. Now after I dive it for for about 20min the compressor sounds like its making a whining noise and it will blow nice a cold for a little while and then I will just start dropping off. Its bad enough that who ever rides in my truck starts sweating including me. And its pretty hot here in Texas.
Does any of yalls a/c suck this bad?
Old Jul 11, 2011 | 11:51 AM
Blue Rebel's Avatar
Blue Rebel
nope, yours is still not right. probably has a leak and your low on freon
Old Jul 11, 2011 | 12:26 PM
White Max's Avatar
White Max
What all did you replace when you got it "all fixed"? When the old compressor failed, it definitely could have put some debris in your lines. Either way, no, the AC in my truck is easily the best out of any of the vehicles I've owned.
Old Jul 11, 2011 | 12:30 PM
Nickk97tml's Avatar
Nickk97tml
Got my Ac "fixed" twice. $400 dollars later and I still have hot air blowing in my face. So I said ***** it and I just roll the window down thats my AC
Old Jul 11, 2011 | 01:48 PM
jpcnorthwood's Avatar
jpcnorthwood
Mine is better than what I have in my car. I love cranking in on after a long day of work, when I am sweaty and it cools me right off.
Old Jul 11, 2011 | 03:57 PM
Roger T. Pipe's Avatar
Roger T. Pipe
On my '96, it's still on the original charge as I've never had the system open. It gets so cold you could hang meat in the cab! Hope this lasts....
Roger
Old Jul 11, 2011 | 04:05 PM
ford390gashog's Avatar
ford390gashog
Was the entire AC system flushed??? When the pump dies you MUST replace the drier and orifice tube and flush with AC cleaner. If that was done you need to check your system pressure!
Old Jul 11, 2011 | 09:30 PM
firewood truck's Avatar
firewood truck
I just got the A/C back to working condition in my '90 F250 and it easily out chills the A/C system in my 3 year old Camry.
Old Jul 12, 2011 | 12:16 AM
6.9idi's Avatar
6.9idi
ive got a/c in my truck that will freeze you to the seat and then my uncle has one that you turn into an ice cube if you aint careful lol its great!
Old Jul 12, 2011 | 02:53 AM
jborushko's Avatar
jborushko
yeah... but i think my problem is the missing a/c pump.
but seriously the pump clutch was whining like crazy and i had no output to begine with when i bought it so i pulled it off and installed a bypass pully
Old Jul 12, 2011 | 08:17 AM
Hunt89's Avatar
Hunt89
Thanks everyone for all the replies. The Compressor gets louder than my exhaust and my tires . It turns heads in parking lots too.
All the lines where replaced.
Roger
Hey thats what im talkin about! I want your a/c lol
Yes it was flushed and the drier and orifice tube was replaced. How would I check the pressure?
Old Jul 12, 2011 | 08:19 AM
Hunt89's Avatar
Hunt89
How would you fined a leak on an a/c system and how do you check the freon. Ive never messed with an a/c system before.
Old Jul 12, 2011 | 12:03 PM
Blue Rebel's Avatar
Blue Rebel
To check the pressures you buy a manifold gauge set, hook it up and run the truck.
Only way to check the amt of refrigerant in your system is to have it evacuated at a shop w/ an ac machine.
Old Jul 12, 2011 | 12:49 PM
Jaime74656's Avatar
Jaime74656
nope, mine does not suck, it only blows...cold air that is still all factory original what not (as far as i can tell) and I have yet to crack it open and change it all, still gets cool as the artic (figuratively) and in the 118 heat index were getting here in Louisville its a welcome thing
so to answer your question...err your other part you may have some debris in your system, or a leak and/or low pressure...
Old Jul 12, 2011 | 01:59 PM
Chaching's Avatar
Chaching
Originally Posted by Hunt89
My truck is in my sig. About 2 years ago my a/c compressor imploded and destroyed my entire a/c system. It was so bad that if I turned on the a/c it would instantly kill my truck HID headlights . I got it all fix now. Now after I dive it for for about 20min the compressor sounds like its making a whining noise and it will blow nice a cold for a little while and then I will just start dropping off. Its bad enough that who ever rides in my truck starts sweating including me. And its pretty hot here in Texas.
Leave the AC on the first 20 min then roll down the windows and GO! lol
