I read a while back you get get the springs for about $600 from a dealer. My dealer is quoting $200 each front and $250 each rear. Where did ppl find them for $600. I just order my sway bar and Belstiens, hoping to save the springs for last. I've had bad towing experience with my 31ft TT and I hope the shocks and sway bar will tame it enough to be safe. I have a long trip planned with the family and I told my wife, nobody will be in this truck till it's safer.
You can plug in the part #'s Stewart posted earlier and see what comes up...
Do a search for Pro Comp 22210/22415 springs as well. You'll find a few threads here where folks have done this swap and new springs, etc cheaper than Ford on Amazon! (there's yer one-stop shopping place!)
So these are aftermarket stock replacement for the v and b Ford springs? Basically what you would change on your F250 if you didn't want Ford springs or any change in ride height?
No, the 22210 is prolly a little taller than a v-code and the 22415 is prolly a couple inches taller than b-code. It appears that folks using 22415's who don't want 'lift' are not using any blocks - I need to read those threads again... I just posted them because they're under $600 and ONE-SOURCE shopping for the OP!
