Parting out '91 F150
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Item Condition: GA
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
longblock- $200-- Was running when pulled with less than 120K miles. However has been sitting out in the weather since Jan without the dizzy in it.
Transmission- $150-- M5R2/M5OD; Has a syncro going out, slight grinding on 3-2 downshift at above 2.5K rpms. Also some fluid leaking from plugs on top I think. Could use an over haul. Does not come with shifter, I modded it to work with my ZF.
Fuel filler neck- $15-- Front tank.
Fuel tanks- $50-- Both front and rear, with sender/pumps intact.
Headers- $150-- Hooker Super Comps, ceramic coated. 1 5/8" dia 34" length primaries, 2.5" 3-bolt collectors. Discolored from Ga clay and some surface rust.
Starter- $20-- Only has a couple months use on it. Reman
Alternator- $20-- Was putting 14+/- .2 Volts out when removed, still on bracket if you want it, also have tensioner.
Smog Pump- $20--33lb/hr
Rad Fan/clutch- $20--
Fuel rail- $35-- With stock injectors/regulator
Intake Manifold- $50-- Upper/lower & throttle body w/working IAB &TPS
Distributor- $35-- MSD cap and I think a fairly new rotor
Transmission Crossmember- $25-- Including the extra side supports that bolt to the top of the frame.
Pwr Steering pulley- $15--
Water pump pulley- $15--
Rad fan shroud- $15--
Intake- $25-- Box with to throttle body tubing and a 300I/460 airhorn that pulls in air from the grill.
EFI engine lift plate- $35-- From Bronco Graveyard
Engine Cradle- $30--
Engine Stand- $50--
Bed liner- $50-- Tuff Liner, hard plastic w/ tailgate cover. Did a decent job of keeping standing water out from underneath since it was on for over 10 years and the bed still ain't rusty.
All parts pulled from truck were in working order when pulled. You pay shipping plus paypal fees if that how you want to pay. Local pickup only for Longblock and Bed liner.
ETA: Also have:
Stock EEC-IV (M1S)- $50
Ext. Cab rear seat- $40--Two piece (butt/back) good condition, no rips or tears, grey/charcoal. Local pickup only.
MSD 6AL model: 6420- $150-- It's a replacement unit I got under warranty and then never hooked back up, so it's still new or newly refurbished.
This is all for now. The main bench seat will be available in the future when I find a good 60/40 or buckets to replace it with.
I do have the compressor and a/c radiator and I think that black canister back near the pass side fan/heater unit still has in-tact connectors. I ripped up the plastic tubing. I didn't list it cause the A/C hasn't worked for years, though I suppose it could've just needed a recharge. What are you looking for?
Originally Posted by jerg_064
Ext. Cab rear seat- $40--Two piece (butt/back) good condition, no rips or tears, grey/charcoal color. Local pickup only.
Originally Posted by truckrider814
Also what about a/c parts?
No body parts, truck got a 408w and ZF transmission along with some other stuff. Here's a list of things pulled so far.
Decided I am just going to part out the whole truck. Prices are negotiable.
Also have a New dual core aluminum radiator from bronco graveyard. Installed and filled, but engine never fired up. $100
Trucks gone, still have the BW1356 transfer case in good working condition...$100
Engine and tranny need a rebuild due to sitting out in the weather, make an offer..
Still have gas tanks that both had working pumps/sending units....
And the dual core alum radiator.
