408w Stroker over 500HP/TQ and accessories
Category: Engine - Complete Motors
Price: $6000
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '92+ Civic/EL & Del Sol, '06+ Civic/CSX, Prelude, Fit, S2000, Integra & '97-'01 Integra Type-R, CL, TL & Vigor, Hybrids
Item Condition: GA
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
Base product is longblock including oil pan/flywheel.
This engine is brand new, no wait longblock professionally assembled by Jim @ Fordstrokers. No dissapointments here!
Engine should produce around 600 Horsepower with a FAT torque curve.
Will sell for $6,000+ shipping/paypal fees if applicable
Contact via PM or phone call/text (931) 289-631ohh
Might trade it and support components for a F350/450/550 PwrStroke 4x4 stick shift
Heres the specs:
408 Liberator 9.5 Deck 351 based stroker
Roller 351 Machined Block
10:1 compression ratio
Probe SRS 2618 Forged Pistons (22cc dish, TFS) 4.030
4340 Forged Steel 4.00 Inch Crank
4340 Forged Steel H Beam Rods 6.200
Perfect Circle Moly File Fit Rings
Clevite 77 Main Bearings
Clevite 77 Rod Bearings
Clevite 77 Cam Bearins
Internally Balanced
Fel Pro Head Gaskets
Fel Pro Pan Gasket
Melling M83 Oil Pump
ARP Billet Oil Pump Shaft
ARP Main Studs
Fel Pro Rear Main Seal
Powerbond SFI Internal Balancer
Canton 8qt. 4x4 rear sump oil pan
Hydraulic Roller FordStrokers Custom Cam
Comp Cams "Ultra Gold" 1.6 Ratio Series Rockers
Comp lifters/Spider/dogbone setup
Heads:
TFS TW "Fast As Cast" 190cc Heads
Cam:
Custom Billet HR Cam specifically for HD truck use.
220/230 duration @ .050
.560/.570
Will get more specific if asked, but I don't have cam card.
Other goods
Intake: Edelbrock Super Vic EFI 9.5--$250
Super Vic billet fuel rails--$50
Accufab 4150 Throttle body--$500
Accel 44lbs/hr fuel injectors--$400
Hooker 6228 super comp 351 engine swap headers--$500 (over 800 brand new)
FMS tall valve covers--$80
Poly motor mounts--$70
March pulley kit--$375
CSR throttle body throttle cable bracket--$30
4" in/out Flowmater 40s Delta single chambers--$150 for both
MagnaFuel Protuner 625 fuel pump--$375
10 and 100 micron -8AN fuel filters--$30
4 port Aeromotive fuel regulator--$100
MSD Billet TFI 351w Dizzy (8452)--$200
Centerforce DF 10.4" clutch (I'll have to look up the p/n)--$300
Also plenty of assorted -8AN fuel fittings and hose...
As you can see/tell every thing was installed with fluids, but never fired up.
Happy Shopping!!!!!!!
grclark351
01-25-2010 04:10 AM
big orange 4x4
09-23-2005 01:08 PM
Broncobirdy
07-21-2004 03:24 PM
