simple intake question..
Old May 4, 2011 | 05:47 PM
roadrash63's Avatar
roadrash63
hey all
what are these 3 holes on the side of this intake manifold?
and any effect on my 69 351w with stock heads.
block off ideas?
thank you
hey next time your at the bar order a ben laden... (no i dont care if its spelled right) two shots and a splash of water....ha ha..... mf a$$ !!!
Old May 4, 2011 | 05:53 PM
Alcaeus's Avatar
Alcaeus
My intake manifold off of an 85 has those. A vacuum actuated door slips in there as part of the emissions crap.
You will need longer intake bolts for the two smaller holes and could "probably" fab up some sort of plate for it if you aren't emissions worried.
Alcaeus's Avatar
Alcaeus
I can take a picture if you like.
Old May 4, 2011 | 05:59 PM
roadrash63's Avatar
roadrash63
hey
thanks for the fast reply
thats what i thought.
no need for a pic
got a carter 625 for it.
way better than my 2v 352 cfm stocker!
Old May 4, 2011 | 06:04 PM
Alcaeus's Avatar
Alcaeus
sounds like your gonna make her breath fire! Do you have headers and are you dumping the cats?
Old May 4, 2011 | 06:24 PM
roadrash63's Avatar
roadrash63
no headers
just a stock set up
still have the cats there fairly new were on it when i got her...
runs pretty good with that 352cfm carb and the 373 gears.
major power increase over the 302 efi 185 hp
the 351w came out of a 69 cougar-240 hp with the 2v
should have bought the whole car
o well just add it it to the list of cars... ive had and lost makes me and my son sad sometimes....
Old May 5, 2011 | 09:22 AM
Alcaeus's Avatar
Alcaeus
I just went from the 300-6 on my 82 to the 302. I dumped one of the cats and I'm thinking of putting better breathing exhaust and a 4 barrel intake on it as well.
3.55 gears is next. It originally had 2.49 and right now has 3.0 gears in the back.
Old Jul 10, 2011 | 07:50 PM
roadrash63's Avatar
roadrash63
anyone know what the parts name is that goes in this hole
hi
anyone know what the part's name is that goes in this hole?
i cant find it in my repair manual or any parts catalog
ty
Old Jul 10, 2011 | 07:54 PM
86fn150's Avatar
86fn150
supposedly for exhaust crossover (vac operated door).to heat up intake under carb(cold weather) from what i've been told
Old Jul 10, 2011 | 08:02 PM
roadrash63's Avatar
roadrash63
ty 86fn150
like your screen name
well its a start i just want to block it off. but keep the cross over fuctional.
gets cold up here in pa.
the manual doent say anything about it at all no pics either...
Old Jul 10, 2011 | 09:01 PM
Gary Lewis's Avatar
Gary Lewis
Have a similar discussion on my thread here:https://www.ford-trucks.com/forums/1...rebuild-3.html I have the same intake and it is off an '85 351W HO.
You'll see my plans in that thread. I'll make up a block-off plate for that valve. But, you will also have to block off the exhaust gas in some fashion. Again, discussed in the other thread.
Old Jul 10, 2011 | 09:16 PM
roadrash63's Avatar
roadrash63
thanks gary
what did you finally do with it?
i was planning on puting a freeze plug in there but have found one to fit yet...
Old Jul 10, 2011 | 09:29 PM
Gary Lewis's Avatar
Gary Lewis
Haven't done anything yet, but plan to make a block-off plate and get a new gasket to go under it. The gasket shows in the pic on the left.
Maybe you could chime in on the other thread? I'm looking for all the input I can get.
Old Jul 11, 2011 | 12:05 PM
roadrash63's Avatar
roadrash63
yeah got it
hey
i found the correct size freeze plug to block this hole off!
DORMAN 555-097 and/or 555-306
both are very close... i will know which is best soon.
Old Jul 11, 2011 | 12:39 PM
Gary Lewis's Avatar
Gary Lewis
Good! Let me know, pse.
