Rear view camera - random problem
Old Aug 15, 2011 | 08:18 PM
  #31
Y2KPSD's Avatar
Y2KPSD
All my cameras work just fine
The one on the factory tailgate
The one on my license bracket (when using my 5th wheel tailgate)
The one on the back of my trailer (connected with a 60' control cable, thru the trailer frame / 5th wheel neck)
No issues.....
I connect my trailer when towing; License plate camera when disconnected; factory tailgate when not towing.....
I have the factory NAV system, and use it's display...
Old Aug 15, 2011 | 08:21 PM
  #32
Y2KPSD's Avatar
Y2KPSD
Originally Posted by dchatcher
Does anyone know where I can get a wiring diagram of the camera circuit as I removed my tailgate for 5th wheel towing and want to install a camera in it. The wiring pigtail part is BC3Z-14A412-A (I think). But will need to adapt it to the pigtail. THX
TDS forums under general category has it all.....
Look back several weeks, that where I got mine from.
Old Aug 15, 2011 | 10:21 PM
  #33
doczenith1's Avatar
doczenith1
I'm partially ruling heat unless it can have a delayed effect. The other day I started my truck which was in the garage (shade) and the ambient temp was around 75 degrees and got the B/W fuzzy screen in the mirror.
Old Nov 27, 2015 | 03:59 PM
  #34
adorebl's Avatar
adorebl
Any solutions?
I know this is an old thread, but i'm having a similar problem with my 2013 F250. Dealer has replaced -everything- except the wiring harness. Thought it was fixed then last night same thing.
Only this time i stepped on the parking brake when i was still in reverse, and the picture came back. Released the brake and it went blank. Repeat several times and the video would go on and off.
Then i put the brake down hard, and released it and the picture stayed on. I'm thinking the parking brake cable is moving and pulling on the harness somewhere. Back to the dealer on monday i guess.
Old Nov 30, 2015 | 01:50 AM
  #35
djkenny's Avatar
djkenny
Originally Posted by DrewF
I picked up my new truck last Friday, and already the rear view camera is having a problem.
Sometimes it comes on, and is all fuzzy and black and white.
Other times, it comes up solid blue, then the display goes off.
Guess I'll be making my first trip to the dealer.....but it wont be the selling dealer, as they are about 70 minutes away.
Anyone else had this issue? I did a quick search, and nothing came up.
Yes have the same issues going on with my 08 expedition EL when unplug and plug back in to the review it seems to be working for minute then goes back fuzzy blue
Old Nov 30, 2015 | 09:14 AM
  #36
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by adorebl
...i put the brake down hard, and released it and the picture stayed on. I'm thinking the parking brake cable is moving and pulling on the harness somewhere. Back to the dealer on monday i guess.
Were you able to drop off your truck this morning, adorebl? How many miles are on it? I'll research ways to assist with your misbehaving camera.
Crystal
Old Sep 21, 2016 | 10:34 AM
  #37
my name is Ryan's Avatar
my name is Ryan
I have this exact same problem. Using the parking brake causes the camera to turn off and on. Truck is at the dealer right now. Been there on two occasions for multiple days and they can't fix it.
Did you ever figure out of to fix the problem?
Old Sep 21, 2016 | 04:47 PM
  #38
djousma's Avatar
djousma
cant answer your question directly, but its been reported that there is a large bundle of wires right near the e-brake that can get scrapped, broken, abraided, etc and caused other problems. You might take a look up in there to see if you see movement, or any potentially bare wires up there.
Old Sep 21, 2016 | 04:49 PM
  #39
my name is Ryan
Thanks for the reply. I got the truck back from the dealer today. They told me that the wiring connector was loose at the parking brake. I've been driving it today with lots of reversing and using the parking brake and no problems so I think that must've been it.
Thanks again.
jonrjen
6.7L Power Stroke Diesel
28
Jun 10, 2019 12:46 PM
duckduke
Jul 13, 2017 06:37 PM
WolfFox
Nov 22, 2016 10:43 AM
bronc71
Sep 23, 2016 07:30 AM
C&C Rodeo
Feb 17, 2016 07:55 PM
