Towing Capabilities?
Old Jul 9, 2011 | 08:10 PM
carolinaborn82's Avatar
carolinaborn82
What kind of weight can you comfortably tow with a 2004 f-150 crew cab with the 5.4l?
Old Jul 9, 2011 | 10:01 PM
air1jpg's Avatar
air1jpg
Open your drivers door and look down on the B pillar. There should be a sticker with your weight limit on it.
Old Jul 10, 2011 | 06:45 AM
TallEddie1981's Avatar
TallEddie1981
Question asked many times.
That number on the b pillar is the amount of weight the truck can carry, not what it can tow. The tongue weight of the trailer does contribute to this weight.
Here is the info direct from Ford that will tell you everything you need to know.
https://www.fleet.ford.com/showroom/...04_default.asp
It seems the general consensus around here is to keep the gross weight under 7,000 lbs.
MeanMom
All Things Towing
18
May 7, 2008 06:19 PM
DCSpecial
Jan 8, 2003 12:46 PM
Redneckerson
Jul 28, 2002 10:57 PM
Debby
Feb 13, 2002 08:22 PM
rabbit stu
Mar 22, 2001 10:34 PM
