Rotor Size/Please Help
Old Jul 9, 2011 | 01:37 PM
BLADE35's Avatar
BLADE35
Originally Posted by bismic
Benny - I believe these are correct:
Brakes, disc, front brake caliper pin bolts (2)......................42 ft-lb
Brakes, disc, rear brake caliper pin bolts (2)......................27 ft-lb
Brakes, front disc brake caliper anchor plate bolts (2)...........166 ft-lb
Brakes, rear disc brake caliper anchor plate bolts (2)......128 ft-lb
Brakes, Caliper Bleeder Screw................................13-18 ft-lb
Thanks a TON Mark just what Iv been looking for
caliper anchor plate bolts I went 135 ft/lbs I will go take them to 166ft/lbs THANKS AGAIN reps to you when it will let me
Old Jul 9, 2011 | 01:38 PM
swamp donk's Avatar
swamp donk
ok i got the caliper assembly off the rotor but cant seem to get the rotor off, am i missing something. any suggestions on how to get it off. i would like to get the rotors replaced on both sides in the front along with brake pads but at the rate its going i will never get this done. Kind of frustrated right now!
Old Jul 9, 2011 | 01:44 PM
BLADE35's Avatar
BLADE35
your not not the only one I just did ball joints and took all that stuff off and EVERYTHING was SEIZED I used PB blaster but dont think it helped much
Take a wood block or something and slam that rotor with a sleg hammer
one side of mine rotor was really stuck gooooood
you will get it remember to antiseize them when you put it back together
some parts on mine needed a puller and a sleg hammer to get them off
If your changing rotors out dont worrey about the block of wood just slam it HARD with a sleg hammer
Old Jul 9, 2011 | 01:49 PM
swamp donk's Avatar
swamp donk
ok i will give it a shot, thanks for all the help guys i really do appreciate it.
Old Jul 9, 2011 | 02:27 PM
Rusty Axlerod's Avatar
Rusty Axlerod
ok thank you for the help. Do you happen to know what size the nut is that i will have to take off to get the rotor off?
Sorry. I was looking at the head of the caliper pin bolts earlier.
Old Jul 10, 2011 | 02:30 PM
swamp donk's Avatar
swamp donk
Hey guys i never made it back to the computer yesterday, but i finally got the passenger side rotor off. It had some kind plastic ring in front of the rotor that was coated with and thin layer of metal it kind or resembled aluminum foil. So i took a flat head and peeled it off and sprayed some PB blaster on it. Then i persuaded it off with a sledge hammer, it finally came off! Thanks for the advice on that BLADE35. After i got everything put back together on the passengers side i moved to the drivers side and it only took me about 45 min to get it done. It was kind of a pain but its done and i don't have any more vibration or squeaking when i stop so I'm happy! Thanks again for everybody's help. OH, and for anyone with an 04 like me I had 13in rotors. Not sure if all 04's would have the same size rotor, but just thought i would share that.
Old Jul 10, 2011 | 03:14 PM
BLADE35's Avatar
BLADE35
mine didnt have a spacer or whatever it was with thin layer tinfoil or whatever
It would have came apart easier if it did I would think
if you dont mind me asking what kinda rotors and pads did you go with
Iv got 75000 on my stock stuff its getting close 80,000 out of a set of brakes is awesome
Old Jul 10, 2011 | 03:38 PM
swamp donk's Avatar
swamp donk
I put the links to the pads and rotors from orielly's site, there is not a picture on their site for the pads. I would have liked to get some better rotors and pads but money was tight so i bought what i could afford. I just wanted to keep my truck safe, later on though i would like to upgrade the rotors to something maybe a little better. Does anyone use ceramic pads and do they really help with keeping the break dust down?
BrakeBest Select 66914RGS - Brake Rotor | O'Reilly Auto Parts
//www.oreillyauto.com/site/c/detail/OBB0/SM756.oap?ck=Search_C0068_1427868_901&pt=C0068&ppt =C0009
Old Jul 10, 2011 | 03:41 PM
swamp donk's Avatar
swamp donk
I don't know what happened with the pad link but they are the brake best select pads that are $35.99.
Old Jul 10, 2011 | 03:48 PM
wulfman's Avatar
wulfman
Swamp donk I have tried the ceramic pads they seem to be to hard my rotors warped pretty quick. Now i just have cheap autozone rotors and rabestos pads semimatalic
Old Jul 10, 2011 | 04:11 PM
BLADE35's Avatar
BLADE35
After my ball joint work Im getting close to needing brake pads at the minimum
I was thinking of sticking with motocraft pads they are going to make it 80-85000miles on the stock ones
IIRC they were about 80.00$ a pair at oreilys for motercraft brand
With that and the new moog ball joints I wouldnt have to get into the front end for awhile
Old Jul 10, 2011 | 04:22 PM
wulfman's Avatar
wulfman
Benny stock pads are great I never wore out my stock ones. I warped the stock rotors then had them turned and put on the ceramic pads and then warped again. Oh now have break controller so no more break issues
Old Jul 10, 2011 | 04:56 PM
  #28
BLADE35's Avatar
BLADE35
can you tell me alittle about a break controller never heard of one what does it do
FWIW all 4 wheels had pretty much the same wear even the back compared to the front
Im just used to my cars I guess they always eat the front brakes first
Old Jul 11, 2011 | 07:19 AM
  #29
swamp donk's Avatar
swamp donk
Wulfman, i heard that the ceramic pads are alot harder and in turn wear down the rotors a little more than the semimetallic pads. This seems to be true from what you experienced. I guess i will just stick with the semimetallic pads.
M88
Feb 23, 2022 06:24 PM
rosesrfree4u
16
Sep 24, 2020 09:48 PM
Ford4dog
15
Dec 17, 2012 06:47 PM
F 250 6 liter
Mar 31, 2011 05:45 PM
