electric rear window
Old Jul 9, 2011 | 12:37 AM
fordspud's Avatar
fordspud
i just bought a 2004 ford f150 larait 5.4 supercrew my back window wouldnt open and when i hit the switch i checked the fuse but it still doesnt work i want to tear in to it but not sure wear to start
Old Jul 9, 2011 | 06:38 AM
MCDavis's Avatar
MCDavis
The window switches in these trucks are notorious for going bad. I replaced my driver's side cluster in March due to similar problems.
It could also be a bad motor in the door itself.
The switch cluster is pretty cheap (around $50) so you might want to start there and go up.
Old Jul 9, 2011 | 06:48 AM
bigunit54's Avatar
bigunit54
The window in my truck has "stuck" before. It is working fine now. But I have had times where I have had to keep hitting the open button a lot of times to open it. One time in particular was like 2 or three minutes. I would hit the open button for a couple seconds, then the close, then the open, then the close and so on. The whole time I was doing this the window was not moving of course, then finally after about 3 muntes of doing this, it opened, I dont know if a connection was corroded or something and it burnt off or what. Lately though it has worked fine. I have had times prior to that where I had to hit it back and forth a few times. Try that, it can't hurt and it did work for me.
Old Jul 9, 2011 | 08:06 AM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
I've replaced the switch on mine, as said that's a common issue for these trucks.
Old Jul 9, 2011 | 12:26 PM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith
Give this a try.
https://www.ford-trucks.com/forums/9...-question.html
bradphx
Oct 21, 2015 05:45 AM
GamalienaireIV
Apr 5, 2015 01:23 AM
Trussonistephen
Feb 8, 2015 12:59 AM
awdonly
Apr 28, 2014 04:16 AM
Dutch123
1978 - 1996 Big Bronco
Nov 16, 2004 12:49 AM
