I did search, and didn't find what I was looking for. 2001 f250 reg cab 4x4 5.4, my goal is a balance of off road capability, street manners, and reliability.
so, I've seen a few people say 35s will fit (with a bit of trimming and correct backspacing) with 2.5 inches lift up front. assuming that's true, would a shackle lift or mini spring pack be best for my goals? the stock springs have a bit of an S to them, which seems like a bad mix with the spring pack, but I'm not sure. also, with a small lift, is anything besides a track bar drop bracket necessary? eventually I'm planning factory skid plates, purple cranium diff covers and limited slip (maybe locker) in the rear. sorry for the long winded newb post, and thank you to anyone with info or advice.
