Sponsored by: Real Truck
Winch Mounting
Old Jul 8, 2011 | 12:55 PM
bigred66's Avatar
bigred66
Winch Mounting
Hello,
Does anyone know if Warn and Ramsey have the same specs for mounting a winch? Specifically meaning are the bolts that mount their winches in the same pattern?
I've got a ramsey 12,000lb winch (RE or REP series) that I'm wanting to mount to a 2001 F350. I'm curious if I will be able to use a mount for a warn winch. Warn seems to have more options available.
Also, if anyone has any Mounts that they like please let me know the model numbers/manf names. I'm looking for just a basic way to mount the winch, not a 2,000 dollar bumper. If I could get away with just buying a tray mound or something like a brush guard mount I would be happy.
Thanks in advance
Old Aug 30, 2011 | 08:48 PM
BrianDguy's Avatar
BrianDguy
Although I dont have any off hand experience with either, they should both use the standard 10x4.5 bolt pattern.
Old Aug 30, 2011 | 08:54 PM
Kajtek1's Avatar
Kajtek1
http://www.harborfreight.com/9000-lb...nch-66409.html
Just run into this one in the store today. It is on sale. Al you need is front and rear end receiver to make perfect setups.
I am using cheapo 8000 lb winch and it has a dozen different holes on mounting plate for different bolting. What would be a problem to make it work anywhere you want?
Old Aug 30, 2011 | 11:03 PM
Callmed's Avatar
Callmed
I wanted to use that style mounting for my winch. But u cant use ur winch really unless ur cable is straight. If u tried a really hard pull at an angle it would more than likely bend. This is what I was told when I inquired on that style mount.
Old Aug 31, 2011 | 12:38 AM
mountie's Avatar
mountie
Originally Posted by Kajtek1
9000 Lb. Capacity Hitch Receiver for Winch
I agree I've had several Warn 12000 winches and they are heavy duty. They'll destroy a receiver type mount in a tough situation.
danr1707
Aug 8, 2017 08:14 AM
iggybob44
Offroad & 4x4
26
Sep 6, 2011 09:42 AM
bigred66
Apr 1, 2011 12:52 PM
Faithful Old Road Dog
Offroad & 4x4
16
Jul 1, 2003 11:14 PM
jimmy102
Offroad & 4x4
Sep 19, 2002 07:35 PM
