Broken connection between key cylinder and ignition switch
Old 07-14-2011, 11:19 AM
kjhansen's Avatar
kjhansen
kjhansen is offline
4wd Low
Fixed. Everything works. Thanks again.
Keith
Old 05-27-2012, 01:46 PM
BAD RONALD's Avatar
BAD RONALD
BAD RONALD is offline
Same problem with a '95 Aerostar. Came across the Steering Column Parts site and became convinced the rack actuator gear (F2DZ 3E723) is the cause. Any advice, cautions, tips, etc. on the fix would be appreciated.
Old 05-27-2012, 10:23 PM
kjhansen's Avatar
kjhansen
kjhansen is offline
4wd Low
I rented a hook-type steering wheel puller from O'Reilly or Autozone and it didn't work. Wouldn't hold onto the sides of the steering wheel center. I had to drill some holes, tap them and use bolts in a gear puller I had to pull the steering wheel. Otherwise it went just as outlined in the instructions I was sent. Good luck.
Old 05-28-2012, 09:36 AM
BAD RONALD's Avatar
BAD RONALD
Thanks Keith.
Glad to find your post. Zero search results in Aerostar forum for this problem. Thankfully this van is only a primary driver for teenagers. Time to organize matters and obtain repair information. I am impressed that replacement parts for this repair are cheap. The instructions from Steering Column Parts will be the most expensive purchase. Funny thing, I got lucky enough to have the original keys from this vehicle turn the replacement lock cylinder bought Saturday at Autozone.
Old 10-21-2012, 02:56 PM
KCFordFANatic's Avatar
KCFordFANatic
KCFordFANatic is offline
Originally Posted by bent-1
I have the same job to do on my 95 F150, sent email as well. After 218,000 mi, I can't complain. The 4.9L runs great & gets good mileage.
Phy, sent you an e-mail as well. I'm about half way into it and could really use some help. If I can save the 19 bucks for the guide that would be swell
John
Old 07-17-2013, 08:56 PM
Dieselamour's Avatar
Dieselamour
Dieselamour is offline
I just broke my '86 and it appears the upper collar and bearing holder can be separated if the two threaded blind pins are removed. It looks like you remove the outer tumbler collar, snap ring, and thread a 10/32 or 24? into the pins and pull them out with a slide hammer and it makes it easily accessible.
The issue is are these two pins actually pins?
Also, I do not have tilt wheel but my ignition actuator appears the same as the link above (but the website says it will not fit my truck) Any thoughts besides resurrecting a four year old thread? lol. Thanks.
Old 12-28-2015, 02:19 PM
Gassman329's Avatar
Gassman329
Gassman329 is offline
Originally Posted by kjhansen
Well, thanks to Phydeaux and the file he sent me, I got the steering column apart and found the broken piece.
http://i223.photobucket.com/albums/d...s/100_1067.jpg
http://i223.photobucket.com/albums/d...s/100_1068.jpg
Now I just have to get the new piece or pieces (although everything else looks fine) and put it back together.
Keith
Hey I'm having the same exact issue. Can you email me the PDF too please?
Old 12-29-2015, 11:30 AM
Gassman329's Avatar
Gassman329
Originally Posted by Phy
You're in luck!
I just found the instructions I downloaded before they changed the web site & started charging for it.
Email me & I'll email back a pdf...
Phy
phydeaux@myqci.com
Hey Phy, do you think I could get this PDF from you as well? Hopefully you still have it.
Old 06-13-2019, 07:56 PM
hennecy's Avatar
hennecy
hennecy is offline
Phy-
Any chance you still have that pdf and could email it to me?
Thanks!
Brad
yrots
01-25-2021 11:36 PM
akamacgyver
07-30-2017 06:13 PM
75_92_95
1978 - 1996 Big Bronco
08-19-2016 10:18 PM
rusty_tank
08-19-2016 05:08 PM
fastcat1977
22
01-30-2016 09:04 PM
Quick Reply: Broken connection between key cylinder and ignition switch
