Brake Lines
Old Jul 8, 2011 | 08:37 AM
fordnut forever's Avatar
fordnut forever
Brake Lines
got a 83 & 86 f-150 and both have rusted brake lines along the frame and no back brakes,lol, must be a common thing for them to rust out as i did a 84 couple years back so off to the parts store for a pair of them,not real hard to fix but kinda a pain.anyone else have this problem?
Old Jul 8, 2011 | 09:06 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I had a rear line rust through on mine a number of years ago at a campground in Gloucester County, VA. I had a devil of a time finding the right combination of lines/fittings to fix it on a weekend.
I kind of needed the rear circuit working for the trailer brakes.
Old Jul 8, 2011 | 09:07 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Anywhere that salt etc gets kicked up can be an issue. They do make stainless line kits but they are a bit pricey.
Old Jul 8, 2011 | 09:12 AM
Franklin2's Avatar
Franklin2
Very common problem. I actually replaced the rear lines on my 1980, and then about 6 years later had them rust through again. When I got the 89, I had the front left line bust open from rust. I just went ahead and replaced every line on it and got it over with. I then painted them, and then smeared grease over lines.
I noticed the parts store I go to now has a green coating on their universal brake lines. I wonder if it last longer than whatever they had on them before.
Old Jul 8, 2011 | 09:19 AM
fordnut forever
the 86 line rusted on one of the clips that holds the lines to the frame, so i'm sure salt got up there and did a number on it,i'll check when i run in and get a new line and ask why they have the green coating on them and see what they say
Old Jul 8, 2011 | 01:59 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
I believe these were first used on European cars. The coating is to help prevent them from rusting. A couple buddies that work in the field have lamented how easily the lines crack when bending them. They've only been using it for about 6 months in shop and they're just as curious to see how they hold up to the salt belt.
Old Jul 8, 2011 | 04:39 PM
orkinman's Avatar
orkinman
i was wondering if sleaving the lines would be worth the time or even effective. anybody try this?
Old Jul 8, 2011 | 04:57 PM
lsrx101's Avatar
lsrx101
I've been in brake line Hell for about 3 years now. Every single car in my family has needed brake lines!
- 3 late 90s Taurus
-94 and 96 Ranger
-95 F-150
-98-Honda Civic
-84, 85 and 89 Lincoln Mark VII (These use 1/4" line to the rear, a monumental PITA to bend correctly!)
-97 CVPI
That's 11 cars in 3 years! I don't know what they're using on the roads these days, but that's more lines than I've done in the preceding 15+ years.
When one blows, I just bite the bullet and buy a 20-25' roll of line and a handful of fittings and replace them all. Often requires one or two rubber lines. Usually if I cut the lines at the fittings and remove them with a 6pt socket, I can recycle any oddball fittings.
God, I hate doing brake lines!
Old Jul 8, 2011 | 05:12 PM
dustybumpers's Avatar
dustybumpers
my 89 has 480,000 miles on it, so after the 2nd time replacing brake lines, when time 3 rolled around, I went ahead and redid everything in stainless. It cost more, but I never have to do it ever again
neilc88
19
Jul 15, 2012 10:00 PM
adam10
Jan 4, 2011 09:32 AM
hugger94
Nov 14, 2004 08:35 PM
bkaudio
Aug 3, 2004 10:24 PM
mmichaelr
1983 - 2012 Ranger & B-Series
Jun 22, 2001 06:14 PM
